Lay down a piece of shop cloth or even newspaper.Lay the dipstick on it then lift off, it's obvious where the level is at.
Easy fix. Sand down the ridges about half way, rounding the edges of the built in ridges. This will make the oil in the piss poor design stand out much more visible in bad lighting and old eyes.
What? You're not using the Guzzi spec white oil? I drill a series of 1/16" holes in the plastic ones. That makes it pretty easy to see.
Yep, that would help too👍I’ve also found that if I get in the sun light I can see the oil line a little better. However tell me more about the white oil😂
He was joking eh!
