you're off your rocker?
There is no tolerance for that here Dusty
I kan't believe you didn't hear an awful racket. I vote operator error last time set.
Well, he did ask--- wasn't trying to lash out, my ears are sensitive to the rocker noise. I would think over 20 thou play gap would show metal in oil or pan if it was impending doom. I'v let my adjustment go 20Kmi and was only 2 thou big. Sorry Norm if I came across different than intended
Go for it, [Ncdan] - it's simple. I almost always get it right. The trick to remember is that it's better to get them too loose than too tight. Not as loose as I did, of course. But the bike was still running great.
whenever you adjust valves, on any engine, rotate the crank by hand at least one full rotation, and check again. takes only a few extra minutes
Clever lad that I am, I decided to change plugs and adjust valves before the rally next weekend.
Sorry, [guzzisteve] - valve/stem/lash/seat were all valve puns, but as they say over on the Halfbakery, " if you have to explain it, it wasn't funny ".[Chuck], that's what my logbook says, but now I doubt my sanity and my eyes, so I'll re-check the log .... after a beer. That's how you pilots do it, correct? I like the operator error theory much better than a cam lobe.Thanks, [yogidozer], I'll buy a socket. I turn the crank over with a wrench, which doesn't fit very well between those charging doohickey fins, and is a minor pain to finesse. Then I'll be cool with doublechecking. Mayhaps that contributed to my getting it off location in the first place. Yes, you fit right in - what are the classes of fit? Clearance, interference, and something else?[LowRyter], it was running great, and the plug looked normal. I'm beginning to suspect that no matter what is really going on in the inside of the engine, when the plug tips hears the socket slide over the end of the spark plug caps, the electrode ends hurriedly put on their makeup and pretend like everything is normal and they've been working hard. Those lazy things probably don't even bother to fire half the time, and just pass the impulse from the coil on to the cylinder and let the two of them sort it out and make it happen.
