Someone said if the hoses let go you'd lose old pressure. I'd like to here what's more major than that.
I replaced the hoses with custom made stainless braided units. Was a major PITA to install or remove. One needed small hands to get the hoses attached internally. Then one day I discovered that the pickup tube doesn't have any screen on it. There was a tiny piece of lock washer in the bottom of the sump. As I was pushing the bike hard through a corner in a small town in Kentucky, that tiny piece got sucked up and sheared the oil pump. One reason to replace the split lockwashers on the rocker pivots with Schnoor washers, as recommended by Guzziology.
Police side stand
If you are not particular about original get a new combo light / signal / horn switch from MG Cycle and sell the original ones on Ebay, they command a big price as they are the same as on the 1st gen Le Mans. You can add another disc, buy a pair of new Brembo calipers from MG Cycle and a replace the old master cylinder. People will pay good money for the original master cylinder, the disc V7 Sport and some early Ducati twins used it.
Yep. The other type doesn't work worth crap. Does it have a center stand?
Have someone show you centerstand technique. Done right, the bike climbs its own way up it like one of Pete's goats on a stripper pole.1) drop stand till it touches2) place toe BEHIND the part that touched3) pull straight UPWARD on the grab handle*.*If no grab handle, a Harley folding footpeg installed upside down near the top shock mount makes a good handle to pull up with.
Switch the 850GT to dual disks. Not interested in doing that to the Guzzi.
Ah bling. Getting rid of rusted fasteners makes a huge difference, its' a nice bike glad you are saving it.
He says that he doesn't ship parcel post to Hawaii. WoW! Mail system works out here like the rest of the U.S.
Yes. I have a sleeved master on my Norton and it's quite lovely.
