The fact that the clutch disengages drive completely and doesn't slip, pretty much rules out notchy splines, IMHE notchy splines symptoms are always an inconsistent (dis)engagement. Creeping forward when clutch lever pulled in again after slight movement (usually negotiating traffic and scary) the classic oneThey look like surflex plates to me and I personally hate them. Hated em in 80's , tried again a few years ago, took them out inside a month. No feel at allBut I recently gave them to Kevhttp://www.guzzioverland.co.ukHe loves them, as do others on here. I like rivetted plates for the feel. I think you'd prefer them too.
I think I've already answered your last question above but rusty plate shows you are seriously gentle with clutch, mine last a long time but you do see shiny where it meets .Possibly a bit of serious abuse would have bedded them in and removed rust without dismantling but you'll be happier with rivetted plates IMHO
Not ignoring your advice. I was just expecting some other serious issue other than clutch plates. I've never experienced this type of trait where the clutch is either IN or OUT and nothing in between -- really dangerous in the Sydney peak hour let me tell you.BTW I have only done a couple of thousand kms on this bike since purchasing it in June last year so know nothing of it's history.I am still contemplating whether to go for the aluminium flywheel or not since mine is still in reasonable condition. If I could find a Le Mans one I would be happy with that.Jackson thanks for all your advice so far. It's appreciated.
Re le mans flywheel, it's pretty negligible gain, lighten yours or buy alloy (twin plate not single) and use rivetted plates.Only 100Sp on are light enough as orig to make a worthwhile differenceChoive between machining yours and alloy one down to $
Problem I have is that I can't find anyone in Sydney that will do the lightening for me, not motorcycle machinists anyway. Not sure I want to entrust it to the V8 car machinists, they probably wouldn't be interested anyway.
Just a couple of pics for Don.This is what happens to the 'Deep Spline' Surflex plates. Usually it doesn't take that long!And one of a flywheel with a badly notched set of splines.Pete
