Author Topic: welding question 75 850 T  (Read 331 times)
Offline Woodrow
« on: April 17, 2024, 12:15:33 PM »
Can someone tell me if the footpegs on my 850 are weldable with common MIG wire ?
thank you
Woodrow
Online xackley
Re: welding question 75 850 T
« Reply #1 on: April 18, 2024, 12:45:23 PM »
If you are talking real MIG, not flux core, you will probably be Okay.
Disclaimer. The only welding on a frame was my goldwing. I used 3/16 70-18 rod to reconnect the side stand. When cleaning the area with a grinder the sparks should be a bright golden yellow. That would indicate typical mild steel.
Don
Edit: There is no down side to pre-heating area to 150* F to ensure slow cooling of the weld.
If the pegs are stainless I would use 309 stainless wire.
« Last Edit: April 18, 2024, 01:04:37 PM by xackley »
1958 R69 BMW, 1972 R75/5, 1980 yamaha XS650, 1982 GL1100, 2003 EV, 2007 Triumph America and 2017 V7!!!
All on the road, going nowhere in particular.
Online Perazzimx14
« Reply #2 on: April 19, 2024, 03:20:49 PM »
The steel on the 850T is nothing special. You can TIG, MIG or stick weld it. Personally I'd prefer TIG.
2017 Road Glide Special
2020 Kawasaki KLX300SM
2016 Suzuki Van Van 200
Offline ital4me
« Reply #3 on: April 20, 2024, 07:28:22 AM »
I would bevel the edges of the crack and use enough heat. You don't want to worry about that breaking at the wrong time.
Harper's Moto Guzzi : Go Ride, Break Parts, Call me!
Harper's Moto Guzzi. Where we still answer the phone, use the highest quality parts, and also do Transmission, rear drive, and carb rebuilds fast. Call us at 816.697.3411 and get your problems resolved.
http://www.harpermoto.com
