Sounds like a dash issue.
I wish HE hadn't said that...
I assume that you cleaned the battery connections well, my 09 Norge gets weird electrical gremlins whenever there is any corrosion or oxidation at the battery terminal. Not trying to be condescending, just saying...
The button for my Griso dash is very difficult to use, sometimes I have to push it dozens of times for it to have effect for example just to reset one of the trips might take a minute but it usually it gets easier with use.On the other hand the Mode switch works well, it always changes the display,I suspect the button has a dirty contact, microprocessors like their inputs to be crisp, no half measures.I have toyed with the idea of opening the dash and connecting a reed switch in parallel. Reed switches have their contacts sealed inside a glass envelope, a small magnet on the outside of the case will always result in a closed contact.
Roy, seems strange that both switches are playing up at the same time the indicator switch is nice and clean but still not working.
Doesn't sound good..
Indeed,The Left and Right indicator lamps are driven from the Dash (4 outputs)34/35/36/37The L/R switch turns on the dash inputs 2/12http://www.thisoldtractor.com/guzzi007/schematics/2007_Norge.gifDoes your dash show any signs of condensation, is the bike left outside at all?
Norge and Griso dashes are different, as are the switchblocks and their operations.Pete
If you can find a partner in crime with the same bike, (Breva/Sport might do as well but the pin out might be different.) you could try swapping switchgear to see if it's switch related.Pete
Post #1I thought it was a good way to cut the pool of possible causes in half..
