Thanks for the kind comments, gentlemen. Turin, I bought the fairing from a cycle shop in the early 80's when I was living in Albuquerque, New Mexico. There is no brand or marking apparent on the fairing, but I was told that it is from Italy.Huzo, I will stay with the red tank for now, but if I decide to have the tank done professionally I would strongly consider gloss black with gold decals/lettering. I hadn't really given it any thought but your suggestion to upsweep the muffler a bit is intriguing. I could do that easily by enlarging the hole downwards on the mounting tab. I wouldn't wanna dramatic upsweep, but as you say, "subtle" might look good. Thanks for the idea!
The V50 "tubeless conversion" was as follows: Removed wheels from bike; Dismounted tires; unscrewed tube valves and removed tubes. The V50's OE rims were not designed for tubeless tires, and thus were delivered with tubes. Experience on the part of numerous Guzzi owners, however, has proven that these tube-type rims can serve faultlessly in tubeless usage.I went around the inside of the rim sidewalls (the area where the tire and rim would be in contact) with some 220 grit sandpaper, used lightly, to knock of any high spots, casting flash or rough patches. On both wheels I used my tap and die set to tap the tube valve orifices to receive an air pressure valve intended for the pressure chamber of an electric water pump. Screwed in the latter, sealing with teflon tape. Very simple and quick installation. With valves now installed, I used tire lubricant to coat the inside of the rim sidewalls, as well as the portion of the outside tire sidewall that contacts the rim. Mounted the tires and they pumped right up. This was years and very many miles ago. Never the slightest leak or any kind of problem since mounting the tires tubelessly.
