Lannis what model Pazon are you using? I am thinking of replacing my Boyer with one. Pete
When I decided to replace the points, I asked a Norton expert friend what he would use. He suggested calling the dude (can't remember his name) at clubmanracing.com and letting him know my wants, use of the bike, what's important to me, etc.The guy there is the real thing. He patiently went over the characteristics of the Boyer, Pazon, Wassell, and Tri-Spark ignitions that he sells. Wassell is cheapest at $119 but was not his first recommendation unless price is a major concern.Tri-Spark is the most expensive, and it's self-contained under the points cover - ie there's no "black box" to mount up under a frame tube and wire in. He said it would be a good choice, and acknowledged, however, that some folks seemed to think it had a higher failure rate because all of the electronics is inside the points cover with the engine heat.He said that the Boyer and Pazon were about equal - I have a very reliable 10-year-old Boyer on my BSA, but went ahead with the Pazon because it will work with no more than 8 volts, and with the electric-start Norton, the voltage drops to 10 or 11 volts even with a hot battery while the starter is turning. It's a Pazon Sure-Fire, not sure of the model number if it has one. It's working great. I did notice that (as opposed to the Boyer on the BSA) that you have to strobe-time it once you set the static timing by centering the dot in the hole. It was a bit too advanced when setting it by eye. On the Boyer, I didn't touch the timing after I static-set it.HTHLannis
Great video...beautiful scenery...fabulous classic Commando!! :1: I wish I had $25K-$28K disposable lettuce laying around, I would not hesitate to have Matt Rambo from the Colorado Norton Works (CNW) build me one...just like this! :1:
Well, this old Norton has been through a lot. Still one of the best bikes in terms of shear pleasure to ride. It has a "Soul" and you can simplyride it by what she sounds like. No ABS, no heated anything. Just two cylinders and whole lot of fun.Click https://www.youtube.com/watch?v=lsxxnYFaddA
Boyers, a single Mikuni, and a belt-primary were practically ubiquitous amongst daily-driver Commandos for a long time. What is the current preferred setup?
I have had both the Boyer and the Tri-Spark and the 'Ol Britts" Power Arc. The Boyer is dated, the Power Arc is ok but has moving parts. The Tri-Spark although it is expensive, works the best. There was a rash of failures with the old units but that has subsided.
I've still got the original Zener charging system on mine, and the original Amals, because they work and I understand them. I took the perfectly good points off and replaced them with a Pazon because I don't like adjusting points on any bike, and because (like any British twin with points/coil) you can't adjust BOTH the dwell AND the timing to be optimum on both cylinders, and I don't like that.Lannis
Erm... what? Perhaps you need to educate me Lannis. I have always understood that the thing with dwell was to have enough of it... that there was a minimum but never a maximum. The twin point (or triple point) set up that was native to these bikes was never going to give a dwell problem with their single lobe cam. ( nor points bounce either)
I'll give you a ring in the next day or so John There is a lot of inter-dependency between the dwell and points gap which also affects the timing, the "fatness" of the spark and also how long the points will last.
Side note , there was a company in the States that made a points cam with two high spots for Brit twins so they could run a single set of points , usually Fairbanks Morse , worked a charm . Dusty
....had no provision to adjust the timing of each cylinder other than setting the timing one cylinder and then adjusting the gap of the other cylinder's points to get the timing on the mark...This may be what Lannis means...? The points work fine when maintained but the auto advance units wear....
Rode my 48 year old Guzzi (Ambassador) ...
