Author Topic: what is the best way to remove sticker glue or residue  (Read 2013 times)
Offline troyhamilton
  • Dr frankie
« on: October 10, 2017, 09:24:02 PM »
after many years im trying to get the glue off of my old windsheild. any tips, this stuff is terrible! dirt is sticking where it used to be decals
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
we need a tech section!
Offline wirespokes
Re: what is the best way to remove sticker glue or residue
« Reply #1 on: October 10, 2017, 10:10:17 PM »
I've used WD40 - it's mild and won't hurt the plastic. It's mostly Kerosene, or so I've heard, so that should work too. Not sure about other stuff like Goof Off - hadn't ever tried it.
Online n3303j
  • Ron Cichowski
« Reply #2 on: October 10, 2017, 10:11:51 PM »
Been using Naphtha for years. Melts sticker glue and doesn't hurt plastics or paints. Can even use it to remove labels from cardboard boxes and stickers from motorcycle windscreens without harming them.
Minor variants that you may have around include Zippo Lighter Fluid or regular Coleman Fuel.
Local harder store carries Naphtha in the paint thinner section (often VM&P varnish makers & painters) labeling.
Makes a great degreaser BUT it is quite flammable so be cautious.
« Last Edit: October 10, 2017, 10:13:16 PM by n3303j »
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline JeffOlson
« Reply #3 on: October 11, 2017, 01:03:59 AM »
WD-40.
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
Offline MotoBug
« Reply #4 on: October 11, 2017, 01:23:23 AM »
WD-40 is handy to know. I've always used gum turps or regular turps but as they say, try it on an out of view place first.
Offline Chesterfield
« Reply #5 on: October 11, 2017, 01:41:57 AM »
Best stuff ever, has never attacked any surface I have used it on. Like WD40 is a myriad of uses.
https://www.johnsonautobodysupply.com/3M-General-Purpose-Adhesive-Cleaner.html
« Reply #6 on: October 11, 2017, 02:03:34 AM »
Eucalyptus oil.
The added benefit is you'll be more attractive to women.
You'll smell like an Aussie. You'll be tossing another shrimp on the barbie !
« Last Edit: October 11, 2017, 02:04:33 AM by Huzo »
« Reply #7 on: October 11, 2017, 05:41:03 AM »
The 3M product works really well.
Online Ncdan
« Reply #8 on: October 11, 2017, 07:19:40 AM »
For tough stuff I was plain old mineral spirits
Offline slowmover
« Reply #9 on: October 11, 2017, 09:20:40 AM »
Gasoline.Just a little on a rag.Don't smoke.
« Last Edit: October 11, 2017, 09:26:42 AM by slowmover »
Frulk
« Reply #10 on: October 11, 2017, 09:46:50 AM »
Zippo lighter fluid. I cover the area with some toilet paper. Squirt it on. Let it set for a few moments to soften up the adhesive or sticker and off it comes.  Been doing that for 30 years on all sorts of surfaces. Never a problem.
« Reply #11 on: October 11, 2017, 10:10:41 AM »
"Best" is many times very subjective. Here is the one that works for me:
https://googone.com/products/original/
« Reply #12 on: October 11, 2017, 10:18:06 AM »
Varsol, AKA paint thinner, AKA mineral spirits is cheap and effective.
Online Groover
    • Scooteropolis
« Reply #13 on: October 11, 2017, 10:23:11 AM »
Avon's "Skin so Soft" works great for sticker glue removal too  :blank:
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #14 on: October 11, 2017, 10:30:03 AM »
I recently added a "Moto Guzzi" decal complete with birdie to the windshield of my Convert. Unfortunately the decal was quite old and the backing paper wouldn't peel off cleanly from the lettering once it was applied. Left a bunch of sticky residue. I tried minerals spirits - no go. Gasoline - no go. Found the 10 year old bottle of Goo Gone - residue gone in 30 seconds.
Offline JeffOlson
« Reply #15 on: October 11, 2017, 10:38:25 AM »
^ Goo Gone is good, too.
I just always seem to have a can of WD-40 around, whereas Goo Gone is always gone when I look for it...
2018 Vespa GTS 300
2015 Vespa GTS 300
Offline TimmyTheHog
« Reply #16 on: October 11, 2017, 10:57:49 AM »
WD40  :1:
and a good old hair dryer...I am inclined to use heat gun as it does get quite hot, yet a hair dryer is just about right.
and good old elbow grease with LOTS of patient...
Currently Bikeless...*cry*
  • Dr frankie
« Reply #17 on: October 11, 2017, 12:45:20 PM »
thanks yall. i get a warm day...ill clean it off
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
