Well Pete............. appears that naming names isn't on the agenda but I remember hearing of this saying which should be considered in cases of such. All that is needed for evil to triumph is for good honest people to do nothing....
I�m not familiar with this engine but for the cam chain to be that trashed in 20K I would say it ran low on oil at one time in its life. I�ve seen this many times with other engines, did you guys inspect the top pin hole on the con rod? Usually that will show signs of lack of oil.
It will be interesting to see if it's blown out the sump spacer gasket leaving it with low oil pressure. I've been thinking about replacing my original with the supposed new improved gasket. I'm all for preemptive fixes, especially after seeing this horror show.
So I know that Pete (as a dealer and responsible person) doesn't want to get in legal trouble indulging in naming of names ....... but just for giggles, what if he had presented this as just a straight photo-documentation of work he was doing on a bike, without any negative commentary whatsoever?Like "Here, for your information as I have done with previous bikes, is how you work on an '09 Griso. This bike was bought new at Silky Slim's Cycles, and was torn down and repaired in June last year by Shaved Ape Motorcycle Repair of Wallamalloo and returned to the owner. It has not been ridden a significant number of miles since then.""First, you remove the valve cover. Note that if "Part A" is in two pieces as in this example, you must be careful about where the rest of it went. Then remove the cambox, being careful that if any bolts are buggered up, you extract them using the proper tools ...."Nobody would have a case against Pete for any sort of libel or slander.Wouldn't matter much, because Pete's head would have exploded in the middle of trying to write it like that .... Lannis
Hi Peter, it makes sense with it being under high load to wear out the Chain. Is this a common problem with these engines?
As with any facet in life, mechanics are fallible. Hell, they are generally the lower idiot levels, aren't they? I apologize for the entire class of idiot mechanics that are out there. Moto Guzzis are not exempt from the problems of the everyday realm. These guys just got it wrong.
He was a navy pilot in ww2 . He flew a Grumman hellcat f6f off the carrier USS Swanee...... He said the first plane he flew had machine guns timed to shoot through the propeller and you really wanted your mechanic to be in a good frame of mind. While stationed in Guam the new f6f planes came with wing mounted guns, he said that was a happy day.
Well, There are idiots and there are mechanics, but there is no such thing as an idiot mechanic. They are two separate groups. I can only think about a story my dad shared with me. He was a navy pilot in ww2 . He flew a Grumman hellcat f6f off the carrier USS Swanee. He told me as a pilot he got many perks on the ship like a private bunk and steak dinners often. He then said he realized the reason for all this special treatment was because as a fighter pilot in the pacific every nights sleep and meal would likely be his last. Most of his flight group never made it home from the war. I asked him once who he thought had the most important job on the ship. Without hesitation he answered "my mechanic". He said he used to order steak at dinner almost every night and bring it three decks down to him and thank him for keeping all his boys in the air. He said the first plane he flew had machine guns timed to shoot through the propeller and you really wanted your mechanic to be in a good frame of mind. While stationed in Guam the new f6f planes came with wing mounted guns, he said that was a happy day. Ever since that story I've had a great respect for mechanics of all types. I probably would not be here if it weren't for one.
It just makes no sense, I don�t get it.
His first planes were probably F4F Wildcats - they had two guns in the fuselage firing through the propellor and two guns in the wings. Yep, you'd want to make sure your mechanic had the interrupter mechanism timed right, and if a little protein helped his judgment, well, it would be worth a few steaks ... !Lannis
Actually the guns are located in the wingsThe F4F-4 was the first version produced in substantial numbers and made its inaugural flight on April 14, 1941. Along with the Sto-Wing, it had an increased fuel capacity of 117 gallons, a 27 gallons reserve tank, with provisions for 50 or 58 gallon drop tanks beneath the wing on hard points. It was powered by R-1830-86 Twin Wasp engine, driving a Curtiss Electric constant-speed propeller. Armament consisted of six 0.50 caliber machine guns in the wings with 240 rounds per gun (rpg).
