i must confess i own a lomax too, mine still has the 2cv engine.the thing used to be our daily transport at one stage. we now run a 2cv as a daily transport.i have a 850T engine waiting for the lomax , but honestly it doesn't really need the extra power. anything over 70 mph is extremely uncomfortable if you are sitting unprotected.try sticking your head out of a car window at 70 mph
the biggest plus of the lomax is its handling , you can throw it around as hard as you want , if you overdo it it will do a very controllable front wheel slide , and loose speed in the process.so roundabouts can be taken flat out, controlling the speed by sliding the front end. it is pretty impossible to roll a lomax , as soon as you lift a front wheel you loose traction due to the front diff. imagine riding a 33 HP go kart on the road , that will slide before it spins or rolls. quite a lot of fun on back roads.
http://www.3wheelers.com/enter.html
Watch opening the "A-Z Tour" on that page - it tried to start downloading a suspicious file when I did.
Sidecar rigs put a smile on everyones face too and also pull the women in.
I ended up with a survey to complete, I had a job to leave the website.
Have you been for a drive in Lomax with a Guzzi engine ? To me it's not so much about speed, it's about how quickly it gets there more than anything. Couple that with the looks and the sound + the good handling and you have a real sports car............ The 70mph example applies to motorcycles too. I have heard from other owners that they are good fun as is.
of course the same on a motorcycle , i wouldnt ride a motorcycle at those speeds without my full face helmet, but what is the point of owning a open sports car if you wear a helmet? nice lomax, mine is the virtually the same , even the same color only difference ,mine has three wheels. i did drive one with a guzzi engine for a very short ride, it is a lot easier to drive, with the original engine you need to be flat out all the time to get anywhere.i would be worried about the life expectancy of the 2cv gearbox with a healthy guzzi bigblock ....
Don't think you'd ever break a 2CV gearbox, maybe kill synchros if the umbrella stick not mastered.I like it, use 3-4 only on the run, nice quick change. 2-3 takes some nutting out but once sussed is good too.4 speed and gearing determine where you take it but I never got to 70mph in bros, actually above 40 impossible to talk/hear. For long trips I'd wear a helmet, and still never go on motorways. Smooth bitumen, tight & twisty is seriously good fun, potholes not so much, back is only half a 2cv suspension on his one (leaf spring turned inwards)Not like a bike to me, wind noise is incredible. Little screen does SFA to quieten it, Bill's windsreen / rag top might do trick.
i have been running 2cv's for 30 years, i've got at least half a dozen broken gearboxes to prove they are not that indestructible.most broke using visa (650cc) engines. the gearbox doesnt like high torque ,so dumping the clutch with a guzzi engine is probably going to kill it.
Interesting. Turnkey Pembletons are available but they all seem to have small block 750 cc engines, I wonder if that is the reason why.. Is that the reason you have not installed your 850 cc engine yet ?
Do you find them more stable than a 2-wheeled motorcycle when road surfaces are less than perfect?
i have been running 2cv's for 30 years, i've got at least half a dozen broken gearboxes to prove they are not that indestructible.most broke using visa (650cc) engines. the gearbox doesnt like high torque ,so dumping the clutch with a guzzi engine is probably going to kill it.not a problem probably ,if you are in a hurry you shouldnt be driving the lomax. if you find the rear suspension too soft you can connect the two swingarms, so you can use both spring canisters
So, how do these various clones stack up against an actual Morgan?I seem to remember a clip of the Top Gear team thrashing the hell out of a Morgan 3 wheeler on a race track without breaking anything.Found a cliphttps://www.youtube.com/watch?v=C8-4IKUntko
For those interested in the Triking cycle car. I am a big fan. For one thing I have been an owner and enthusiast of Moto Guzzi since 1978. Had a T3, SP,CX 100, now a Triking cycle.
JZR is looking great Fred ! Where did you source those mirrors ? Looking for something similar for my JZR. Bill
