Author Topic: How to remove EV ignition switch?  (Read 2341 times)
Offline flower_king001
« on: October 29, 2018, 09:48:23 AM »
Hi,
 Having some issues with my '98 EV and wish to remove and clean the ignition switch. Can someone give me the steps in doing so?
Thanks, Brian
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Re: How to remove EV ignition switch?
« Reply #1 on: October 29, 2018, 09:55:20 AM »
If I remember right those are tamper proof bolts so you have to cut a slot for a  screw driver into the head? With a dremmel tool maybe.
Offline wavedog
« Reply #2 on: October 29, 2018, 10:03:37 AM »
Or just ride it until the tamper proof fasteners vibrate loose, fall off and the switch falls down into the area between the triple clamps and steering head. That was fun.
« Reply #3 on: October 29, 2018, 11:39:07 AM »
I saw this post from sometime back:
https://wildguzzi.com/forum/index.php?topic=94262.0
To get the assembly out I figure one must unbolt headlight and move out of the way and then remove the two Phillips screws holding the unit to the top triple tree clamp?
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
Online Chuck in Indiana
« Reply #4 on: October 29, 2018, 11:49:28 AM »
Yes, although they "might" be hardened anti tamper screws. I don't know.. but if they are, this job just got a lot more difficult. You should be able to see them with a light and mirror. Report back.
I had to pull the switch on the MZ (same Zadi switch) and it had the anti tamper screws buried to where you couldn't get a cutoff blade on a dremel in to slot them. Had to pull the triple and laboriously tap with a punch and hammer a few million  :evil: times.
Albert Einstein
« Reply #5 on: October 29, 2018, 01:06:03 PM »
Yes the EV switches are just two Phillips screws
Make sure when you put it back that the wires are not flexing at the solder joints or they will snap off pretty quick.
I like to attach them to the rear cover somehow.
The loom should bend gently over several inches as you move the forks from lock to lock.
You can service the switch in situ if you disconnect the battery negative or unplug it on the left hand side under the tank and do on the bench, watch for the little contacts and springs that pop out.
Air your other issues, there's many on here with EV experience.
« Last Edit: October 29, 2018, 01:12:03 PM by Kiwi_Roy »
Half a V9 Roamer
« Reply #6 on: October 29, 2018, 01:16:34 PM »
 A gram of C-4 will normally do the job .
Offline JoeB
« Reply #7 on: October 30, 2018, 06:23:26 AM »
When I did mine I removed the headlight and as Roy suggests removed the two phillips head screws holding the base of the switch. This separates it from the top barrel where the key is inserted. A brief period of the noted monkey mating ritual dance will help when trying to access screws.
Later on one of my first rides, like wavedog, I found the whole unit will drop out. As stated there are two bolts holding the unit in. On mine I think only one was tamper proof. They both worked their way loose and were easily unscrewed and replaced. My keen diagnostic skills  :rolleyes: noted the ignition key sinking down as I was riding along.
« Last Edit: October 30, 2018, 06:38:29 AM by JoeB »
« Reply #8 on: October 30, 2018, 10:02:45 AM »
Thanks Joe...most appreciated!
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
« Reply #9 on: October 30, 2018, 10:03:50 AM »
Most appreciated!
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
Offline JoeB
« Reply #10 on: October 31, 2018, 07:59:23 AM »
If you do remove the headlight mark a line or couple dots with a sharpie like marker from the bracket to the light where it bolts on.
On reassembly line it up and you should be close to original alignment for your light beams.
Not an in-depth technical tip but may save some time.
Offline john fish
« Reply #11 on: April 27, 2024, 05:04:12 PM »
Got the bottom of the switch off. What next?  Do I disassemble the bottom and clean it?
Do I have to remove and.clean the top part tgat the key goes in to?
He lost the run of himself.
« Reply #12 on: April 27, 2024, 05:59:59 PM »
Yes.
Don't bother.
Albert Einstein
« Reply #13 on: April 27, 2024, 09:22:33 PM »
The part you want is on the end of the loom.( Edit, I just checked the picture, I was thinking of an older switch ). Mark the housing. Fold up the tabs. Be careful to capture any springs and balls as you separate it. Inside you will find the sontacts you will clean. Snot a big deal after you’ve done one. Newer switch:  Push in the plastic tabs while pulling the two halves apart.
« Last Edit: April 27, 2024, 09:30:04 PM by John A »
Offline John Croucher
« Reply #14 on: April 28, 2024, 11:17:58 AM »
Loosen the two top fork pinch screws. Take the screw out of the steering shaft, pull the top triple tree up and off with everything connected and turn over and lay on gas tank on a soft blanket.  Remove screws on bottom of switch. Take a picture so you know the correct order of the contacts.  Clean and re assembly.
Offline Matteo
  • Alaska Guzzi's on Facebook
« Reply #15 on: April 28, 2024, 12:29:46 PM »
That's how I got mine out
Offline elrealistico
« Reply #16 on: April 28, 2024, 04:25:52 PM »
Maybe a spritz of Deoxit?
2018 V7III Special
1978 T140V Bonneville
2004 EV Touring
Offline dguzzi
  • Sorry, I'm woke so I'll be quiet.
« Reply #17 on: April 28, 2024, 05:10:33 PM »
  Even Lucas likes DeOxit!
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'90 Miata
'16 Mustang
Harper's Moto Guzzi : Go Ride, Break Parts, Call me!
Harper's Moto Guzzi. Where we still answer the phone, use the highest quality parts, and also do Transmission, rear drive, and carb rebuilds fast. Call us at 816.697.3411 and get your problems resolved.
http://www.harpermoto.com
