Had to do the same thing when fitting the center stand on my V9. It had to have a crazy amount of washers inserted as it was the stiffest pair of springs I have ever encountered when it comes to stand springs, and they are always extended, regardless of the stand's position.
When I had to do this I got a piece of 1/2" copper tube and squashed the last inch or so such that it would still slide over the spring mounting pinI then chopped it to length such that it would pivot up and down when installed on the pin - only about 4" long to clear the obstacles To use, you put the tub on the pin with the end down towards the spring Hook the spring over the squashed copper tubeThen use the leverage of the tube to lift the spring up, if you're lucky it will slide off the end straight onto the pin, but you might to have to give it a shovePS I used copper because that's what I had available, any squashable tube would work 👍
Attach the springs on each end before putting the pivot screws in. Makes it a lot easier.
