Does it run evenly on both cylinders with no missing? If not, change out the plugs.
Maybe you drowned the sensor in the intake with oil. It might be worth spraying some map air sensor cleaner in while running.
Next time you change oil put 1 1/2 quarts in a bottle and dump it in. Then ride it a bit and check. If you really feel it needs more put in 3 ounces at a time. V7's don't hold 2L like the book says.
You should take that test ride then ask the question if still slow.
What quality compression tester did you buy…
…and have you replaced the fuel filter?
Compression is indicating a little high but I'd consider it more a tester issue then an engine one. Ciao
I’ve run into a few instances where the “crumbles “ in the fuel system are from old fuel lines deteriorating internally (possibly an older hose ) that doesn’t like the alcohol content of newer fuels ? Chased this on an older airhead & a small excavator. I hope this 411 helps .
