I tried to find the download on Guzzidiag for the P8 ('98 EV) and I'm coming up blank.
I tried to find the download on Guzzidiag for the P8 ('98 EV) and I'm coming up blank. I tried using the 15M download and it does not work either. PeHayes can you point me in the right direction?
I hadn't noticed or worried about this before. I was playing around this evening with my GuzziDiag. I have two 1998 EV with P8 ECU and PF3C TPS.Using GuzziDiag version 0.47 to read various data and confirm sensor functioning. I realize this is 'read only' and that you can't actually adjust anything on the P8 via software.When you use GuzziDiag, first thing is to browse to "File" then "Preferences" to scroll through and select your motorcycle model and its FI components.There are two selections for California 1100i:The first is California 1100i with P8 and PF09.The second is also California 1100i with P8 and PF09.Not sure why there are two identical. What's going on inside? Should one of them really be labelled for the PF3C TPS?Under California EV there are two selections:The first is California EV < 2001 with P8 and PF09.The second is California EV > 2000 with 15M and PF3c.I just never paid attention before and just selected for the P8. I have been using the second 1100i option. It appears there DOES NOT EXIST a selection which precisely combines the P8 ECU with the PF3C TPS and these are what a 1998 EV is fitted with.I suspect the ECU choice is more important than the TPS choice. Hence my use of the second 1100i option.Anyone else using this software on 98EV care to comment? Some time from 1996 through 1997 Guzzi/Magnetti Marelli transitioned from the PF09 to the PF3C. Is that second 1100i choice just a typo error as to TPS? Is that first EV choice just a typo error as to TPS? More importantly, do the PF3C and PF09 both put out the same millivolt report at the same angular rotation. (Hence the TPS choice doesn't matter so much.) Does the current 0.50 version of GuzziDiag perhaps correct this oversight?Opinions sought.Patrick HayesFremont CA
