Nice.Amsoil or standard stuff?Also, this battery okay? https://www.batterystuff.com/powersports-batteries/YTX20CH-BS.htmlThank you!Richard
Amsoil all the way! They have 15/60 for Indian/Victory which I use (2016 Eldo) and they have 10/60 dirt bike oil. Either one will be fine. I have used Amsoil for over 20 years and I have never had any kind of engine failure.
This would be a good time to get the owner to round up both of his keys, and make sure he knows or can find the user code. (If he can produce two keys, OR the code, he will be able to re-establish two coded keys and a user code by following instructions in the owner's manual.)It would also be a good time to grease the swing-arm linkage and rear shock, and maybe the steering head bearings.Moto
Also, its upside down!
With regard to oil light coming on, double check that it is indeed a 2015 model. I believe that earlier years some bikes had issues with the sump spacer gasket blowing out internaly between the spacer and the block and known to have destroyed motors due to oil pressure loss. Remedy is to replace with thicker updated gasket. (PN GU01003650)2015 on use the one piece sump same as Cali 1400 and different internal plumbing so weren't subject to that problem.Just a heads up.
