Any fueling issues? I assume you didn't mess with any type of refueling gizmos or tunes, just the stock set-up? Do you have a link to the headers and crossover you went with? I have just a slip-on but wouldn't mind some more sound. I'm a bit hesitant though with removing the cat without providing a tune to match but it seems there isn't much out there that works well with the E5.
https://www.ebay.com/itm/404557029817?fits=Submodel%3ATT%7CModel%3AV85%7CMake%3AMoto+Guzzi&itmmeta=01HRZ9V5AV682ACBAQ2MNRSNSQ&hash=item5e317a61b9:g:zXYAAOSwLQlkjAYD&itmprp=enc%3AAQAIAAAA8NRtemZEBkQXT9GwJiOG%2BizHVw4D4pXSs%2Fjz7nin3mmvzhtYvPIGPGFwU1iA7WJhfgIO3V1ysF2oC8JNKiZAfiFfMRQlQS3qMEjssP1PbvgiiUY3zzb0DJBSBheXOw4dOr%2FyECgom4%2FeEcNcxqrMxFTETcUUvRvyHOYs2egzEXWQq0qXhSjTPzKe4s2mh3nAKGvREIA%2FIqnddrNaZCCqLCvqebkTnZOs9I9MnO%2F%2BLBdDUvV3ym4vxPzjJWSCp4GjWl6rjWYuXkyr8o8CIYFndc2FXNEiEtwXlm0N2no8KW8ucuZasPEJXMcd7shh5UUWHw%3D%3D%7Ctkp%3ABFBM7NXs6cdj
Just asked them to make sure that it had the latest map otherwise, stock. YMMVLeft the stock muffler on as well.inditx
I assume the heat shields are now gone? How about a right side pic.
I also have to thank inditx for being the guinea pig on this item.I finally installed mine and took the V85 out for a test ride and am very pleased with the results. Mostly because not much changed except for all the space under the gearbox.It's not much louder that I can tell. Runs perfectly, as before.I think I will change out the solid bushings for some rubber ones though.Thanks inditx and cappisj1!Cheers!Craig
