The 16M ECU that has a removable chip, all open loop. Trim screw inside a rubber plug for idle mixture next to chip. I got chips years ago w/new model, now not so much.
My yellow '97 has a Will Creedon chip too. I don't know anything about my particular chip, what it's coded for or anything, but it works well with a Mistral exhaust like the one pictured at MG cycle.It didn't run right at all when I first got the bike. After doing the TB balance to a fare thee well and replacing the cam chain tensioner, I think the best results were achieved by setting the valves to RaceTech specs. It runs pretty good now. The idle will miss occasionally, but it never dies. The miss at 3000RPM is gone. And it's lots of fun. Sounds very sweet; just the right loudness.The little screw on the PC board is for mixture at idle only, to be set with a CO meter, as I understand it. I have it set somewhere in the middle, using my best guesswork.FarmallASteve
I have the Creedon chip in it, already adjusted as rich as I can get it.....
Hey Bull TahrIs your Creedon chip new? I wouldn't mind comparing any numbers on your Creedon chip to mine. As you can see in my photo, the number on mine (WPC12-32K) is written in ball point pen on a slip of masking tape stuck on the chip. It was already installed on the bike when I bought it last summer and seems to work great after the setup I described. But I don't know anything of it's provenance. Just curious.
