I hope your being real careful with the pinch bolts, a little tight then over to the nextdoor one, a light twist and back and forth. You can crack the fork leg if you were to really reef on it. Might even be worth using. Torq wrench.
fotoguzzi has a point, maybe use a torque wrench, you want to get it right.When i first went through my Sporti, I found a pinch bolt missing on the bottom triple tree. Then a couple hundred miles later a found that one of the axle pinch bolts was missing too. i had never checked their torque, but i'm sure all four were there. The other three were only finger tight.It's nice that the PO didn't crack the fork leg, but I'm also glad the front wheel didn't fall off.FarmallASteve
Oh yeah, you do this before the axle nut, right? Or after?
