Author Topic: Norge front forks  (Read 398 times)
Offline Luisamerico1
Norge front forks
« on: September 29, 2022, 06:53:03 AM »
Hello, could someone clarify a doubt, in the front suspension of Norge there is a black tube that has a metallic washer, it is leaning against the spring, but with the part that has the metallic washer, or the spring enters the tube and the metallic part stay down.
Re: Norge front forks
« Reply #1 on: September 29, 2022, 02:15:41 PM »
Are you talking about the washer in between the tube & spring ?
Yes, this is so the spring does not scrape into the tube. That would create shavings in oil.
« Reply #2 on: September 30, 2022, 06:02:17 AM »
I was in doubt because when dismantling the suspensions I found the spring inside the black tube and the part that has the metal washer down.
The manual does not clarify the correct position of the tube, I also thought that the spring should touch the part of the metal washer.
Thank you for your help.
Offline Huzo
« Reply #3 on: September 30, 2022, 11:00:04 AM »
This suggests that the black tube is lower down and the cap winds against the spring.
But I must admit, even after having changed the fluid 9 times, my memory doesn’t recall where the washer sits.
« Reply #4 on: September 30, 2022, 11:08:31 AM »
The spring should not be in the tube, this is what the washer is for even though it's not in any diagram.
