The EV is a Tonti frame so that helps. 41mm vs 35mm. I nee to see what the offset is. Plus they're adjustable. Definitely an option.
The EV forks have 45 mm tubes.
45mm, some big meaty tubes... Me and Mr Petrus are friends and often ride together..I have done many fork swaps and look forward to helping him if necessary..My lathe will be humming making spacers , steering stem and or axle or whatever it takes.. If the yoke offset is where it needs to be, the rest just falls into place...
Got the forks From CColi-excellent! I will post the swap when I get to it.
The EV triples have a way longer steering stem likely, that will have to be dealt with somehow. DonG
Both the Cal II and EV have frames with the tall steering head.
