Author Topic: 1994 Moto Guzzi California  (Read 1721 times)
Offline nc43bsa
Re: 1994 Moto Guzzi California
« Reply #30 on: June 23, 2022, 08:55:18 PM »
Can't find any photos, but here's a later version with the same linked brakes, that I purchased eighteen years ago in Los Angeles, and it now resides with me in Auckland, NZ.
That's nice!
I don't think I've ever seen a red/silver one.
1990 MilleGT
« Reply #31 on: June 23, 2022, 09:34:09 PM »
That's nice!
its the 75th Anniversary edition.
Offline Murray
« Reply #32 on: June 24, 2022, 09:42:41 AM »
Some Bosch parts fit.  Definitely check the sensors for "swarf".  If you find that it's the ecu, the low cost option would be to retro fit to points/condensor igntion.  I don't that it's the ecu.
Fitting a cam with a gear drive is not a low cost option.
Offline guzzista
« Reply #33 on: June 24, 2022, 10:32:16 AM »
I owned a Cali 1100i same color scheme, purchased new at the now defunct Moto International. Racked up about 60k miles. Perhaps not much in the Guzzi world, but the bike was  very reliable during the 5 years I owned it. Pyro Dans relays were swapped in for good measure, and they are still in use in my current ( 1994) Cali carb.  As others have pointed out relays or  a bad sensor signal could be the cause.
A small, but important bit to check out , is the MAP sensor vacuum hose, which can perish internally and suck shut, causing rough running and a code for flywheel sensor. It is hidden on left side of bike going into  the airbox and not too visible. Moto America signed off on a new ECU for my bike when my local dealer was not able to locate a sporadic cutting out problem. The new ECU seemed to have better drivability than the original, but did not solve the problem, which I found by accident while replacing a battery.
