Author Topic: New Fuel Injectors on 1200Sport  (Read 1099 times)
Offline willowstreetguzziguy
« on: January 20, 2022, 12:15:01 PM »
I needed to replace my Y fuel line under my gas tank and In doing so the other week we broke one of the fuel injectors but that was a good thing! I ordered two new injectors and replaced them last night and the results were amazing. No more popping during deacceleration, the engine is smoother, even at idle and I sense better throttle response. I guess when your injectors are 14 years old, new ones make a big difference! Looking forward to see if gas mileage changes.
« Last Edit: January 20, 2022, 12:15:40 PM by willowstreetguzziguy »
2008 Guzzi 1200 Sport
Offline AH Fan
Re: New Fuel Injectors on 1200Sport
« Reply #1 on: January 20, 2022, 02:51:57 PM »
Good stuff Willow.
Mind if I ask who you went through to get those?
Ciao
Offline CanBike
« Reply #2 on: January 20, 2022, 06:57:16 PM »
Where did you buy the injectors?
Offline lucky phil
« Reply #3 on: January 20, 2022, 07:20:38 PM »
It's usually cheaper and just as effective to simply have them cleaned. What did you pay for them? Some are very expensive new even using equivalent automotive ones. Side flow injectors on 8 valve Guzzis and some Ducatis are also a bit painful to get cleaned.
Ciao
« Reply #4 on: January 21, 2022, 04:00:54 PM »
Like I started this thread,  I needed one fuel injector to replace the broken one on my 1200 Sport.  Called my closet Guzzi dealer. He said they were $165 and he might have one but after checking, he did not. If he did, I would have driven 2 hrs round trip to buy it!  He said if there were any in the states it would be up to 3 weeks to get in and if ordered overseas, 4 months!
He mentioned that if I checked the number on the injector, I might be able to find it elsewhere. After a google search, I found that Harley uses the same injection on one or several of their bikes. I called the Harley dealer and yes they do use them, they're $65 but they don't have any in stock and not sure when they would get any in.
I did an Amazon Prime search and found them for $17. I ordered three... replace two and have one as a spare.
Like I mentioned, after installing both new injectors, the bike runs great. So I ordered two more just in case I can't get them again.
Offline PJPR01
  • Norge, Scura, Griso
« Reply #5 on: January 21, 2022, 04:40:16 PM »
That's a good price!
I found a couple last year for my Norge on Ebay:  Paid $58 bucks for two of them...works perfectly!  Shows the part number compatibility below.
FUEL INJECTOR Ducati 28040051A,   Moto Guzzi GU05115730,   MV Agusta 8000A3037
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
« Reply #6 on: January 21, 2022, 04:43:22 PM »
A small number on my injectors is IWP 162
Offline lucky phil
« Reply #7 on: January 21, 2022, 05:20:54 PM »
Yea that is a killer price, not worth cleaning them for that money.
Ciao
Offline CanBike
« Reply #8 on: January 21, 2022, 06:08:54 PM »
I have an '08 Sport as well. Might you have a link for the amazon injectors?
Thanks!
« Reply #9 on: January 21, 2022, 07:06:44 PM »
Thanks!
Google : HiSport Store   And look for IPW 162.     Got mine From there on Amazon Prime
OR
Google IWP 162 fuel injectors      (Looks like FL Tour Glide & Ducati Monster 696 use the same)
3rd down: Best Deals
2nd from left
Offline CanBike
« Reply #10 on: January 21, 2022, 07:43:32 PM »
OR
2nd from left
Found it. Thanks!
Offline GuzziOrDeath
« Reply #12 on: January 22, 2022, 12:46:35 AM »
Caveat Emptor.
These are cheap knock-offs. I know a guy who used them in his Sport and it was over-fuelling. The flow rate is not the same as a real Weber-Marelli IWP 162.
« Reply #13 on: January 22, 2022, 07:43:53 AM »
closet Guzzi dealer
Yeah, there are a few of those..  :smiley: :boozing:
Albert Einstein
« Reply #14 on: January 22, 2022, 12:31:40 PM »
Caveat Emptor.
I’ll keep an eye on the two I installed. Thanks for the heads up
« Reply #15 on: January 22, 2022, 01:01:44 PM »
I'd put in new outer plugs and check them at different throttle openings or not they should be consistant w/old ones. The no more pop on decell should tell you they are richer .
Offline lucky phil
« Reply #16 on: January 22, 2022, 03:10:01 PM »
Of course you could always take them to an injector specialist and he can put them on the cleaning and testing rig and measure the flow and check the pattern. You can then compare the flow rate against the stock injector figures which are readily available. Would only cost peanuts to do while you wait most probably. Getting cleaning, flow and pattern checks done is cheap so a quick run on the rig wouldn't be expensive and then you'd know what these ones are like if it's a concern. I'm currently building a rig for cleaning and testing side flow injectors which are a bit of a pain to get done commercially.
Ciao
« Last Edit: January 22, 2022, 03:11:23 PM by lucky phil »
