Is the 80-90 psi good enough for starting and running, albeit poorly?
What Charlie said. The low compression coming up with oil indicates stuck rings. Put the carbs on and get it running. Converts have cast iron cyl. liners and are very durable. Let us know what happens. Cheers
Ive never even ridden a Convert, so not sure if I would want one or not. I know there are some Convert champions on here, so I welcome input!..:-)
On another note, how much play should there be in the driveline when I spin the back wheel? There seems to be a bit of a clunk when changing directions. I checked the ATF fluid in the drive reservoir itself, and didn't smell burned.
