Author Topic: A good project for winter boredom!  (Read 2054 times)
Online Ncdan
« on: January 07, 2022, 10:00:59 AM »
A couple nights ago, simply out of boredom, I decided to entertain myself with a project  that could be of a constructive nature.
I got our my met-wrench tools, rolling stool, a hot cup of Joe  and cranked up some 80’s rock hits.
My goal was to see how many fasteners I found on my 02 Stone that were not tightened to acceptable specs.
I found 3 that were totally too lose and were about to be lost or cause problems and several others that accepted a more appropriate torque spec that they were presently at.
If any of you folks find yourselves in a bored status try this procedure and report back. You may even prevent a further failure from occurring with your bike👍
Dan
Online Cam3512
Re: A good project for winter boredom!
« Reply #1 on: January 07, 2022, 10:08:21 AM »
Did you add a dab of loctite or anti seize where appropriate?
Online Ncdan
« Reply #2 on: January 07, 2022, 10:17:17 AM »
No I did not but that’s a great response that I will try to remember for next time! The fact I found the ones lose that I did would indicate that there are vibrations at those areas of the machine and loctite is appropriate. Thanks Cam👍
Offline yogidozer
« Reply #3 on: January 07, 2022, 11:00:12 AM »
Oh come on Dan, that's too easy.
Try that on an ironhead Harley.
You'll be asking yourself, "There must be ONE tight one someplace"
And then you'll look up outside and it will be 80 degrees and sunny  :grin:
Online Tom
« Reply #4 on: January 07, 2022, 12:26:26 PM »
My Buell Thunder S3 sheds fasteners on a regular basis.  Loctite. :thumb:
From the Deep Deep South out in left field.  There are no stupid questions.  There are however stupid people asking questions.  🤣, this includes me.  😉
« Last Edit: January 07, 2022, 12:35:23 PM by John A »
Offline xackley
« Reply #6 on: January 07, 2022, 01:47:24 PM »
After a year of seeing oil spots under my R69, I finally laid down to check it out.
All the oil pan bolt easily turned a quarter before beginning to snug up.
I do believe I might have fixed the problem.
Don
1958 R69 BMW, 1972 R75/5, 1980 yamaha XS650, 1982 GL1100, 2003 EV, 2007 Triumph America and 2017 V7!!!
All on the road, going nowhere in particular.
Online Ncdan
« Reply #7 on: January 07, 2022, 04:28:54 PM »
Don
Maybe this confirms there’s some validity to my suggestion 🤔
One of my loose fasteners was a handlebar bolt!
Offline Scout63
« Reply #8 on: January 07, 2022, 04:42:31 PM »
Seems like a lot of work to prevent the odd front axle nut from falling off...
Ben Zehnder - Orleans, MA USA
« Reply #9 on: January 07, 2022, 04:47:39 PM »
Don't forget to use the metric lock tite  :thumb:
Online Tom
« Reply #10 on: January 07, 2022, 05:00:33 PM »
Y'ep.  The metric molecules are smaller and only work on metric bolts.
Offline lucian
« Reply #11 on: January 07, 2022, 05:22:45 PM »
Nice work Dan. a lot of winter left . you want to come up and check your Maine bikes over it should be spring by the time you get em all tightened up :boozing:
Online Ncdan
« Reply #12 on: January 07, 2022, 05:29:52 PM »
May just take you up on that offer Dave, boredom can drive a man to do strange and bazaar things🤔🥶
Offline moto-uno
« Reply #13 on: January 07, 2022, 05:50:22 PM »
  Bizarre :) . The other's a shopping place . I'll shut up now :) Peter
Offline kballowe
  • - Kevin the Great -
« Reply #14 on: January 07, 2022, 05:52:19 PM »
If you need more to do, then you could detail and polish the beast.
Get a tooth brush, some ice cream sticks (both sizes), etc.
Mr. Clean does a good job on grease and has a pleasant smell.  Two inches in a quart spray bottle
« Reply #15 on: January 07, 2022, 06:06:29 PM »
Since the weather turned cold I was getting cabin fever. I decided to paint the marred paint on the drier and also cleaned my textile jacket.
The instructions are to hand wash, BTDT. So I threw caution to the wind, stripped out the armor and put it in the washer on delicate wash, cold water. Took it out and dried it on a hanger in front of the fireplace. I was surprised that it was mostly dry in a couple of hours. The jacket looks clean, despite some UV fade, more brown/purple than black. Hopefully the jacket is still water resistant.
I might give the mesh jackets and leather jackets a try next.
Online Ncdan
« Reply #16 on: January 07, 2022, 06:09:42 PM »
I guess it’s not safe to trust the spell check without re reading.
No need to change it now the damage has been done and your Superior intelligence is duly noted😂👍
« Last Edit: January 07, 2022, 06:48:17 PM by Ncdan »
« Reply #17 on: January 07, 2022, 08:19:07 PM »
My winter boredom project has been tearing out the old wooden shelf unti I had next to my workbench, the chip board shelves had sagged and in one case cracked.
I found a store selling used warehouse shelving and racking, 49" wide, 32" deep amd 8' high with 8 shelves, all lock fit no fateners and powder coated for under $400. Had to move the bench over a bit and remount all the steel peg board and sort out tool placement.
everything off the floor and all the handtools within reach
« Reply #18 on: January 08, 2022, 06:43:48 AM »
Beautiful.  :thumb:
My Winter project..
Starting to fab a motor mount..
Albert Einstein
Online Moparnut72
« Reply #19 on: January 08, 2022, 07:30:13 AM »
What make is that engine?
kk
Mopar or Nocar
2023 V100 Marina
2019 V7lll Special
MGNOC #24053
« Reply #20 on: January 08, 2022, 06:08:53 PM »
kk
Verner. Czech.. 42 thumping horsepower.  :smiley:
Albert Einstein
Online Ncdan
« Reply #21 on: January 08, 2022, 06:26:43 PM »
What kind of vehicle does the motor go on?
Online Moparnut72
« Reply #22 on: January 08, 2022, 07:16:44 PM »
I once worked on a 3 cylinder Zekeley (sp?) manufactured in Holland Michigan. I left before the engine was finished. It wasn't a high quality engine.  I don't know why the boss even took it in. There were two of them, hopefully we could make a running one out of the two.
kk
Mopar or Nocar
2023 V100 Marina
2019 V7lll Special
MGNOC #24053
Offline Motormike
« Reply #23 on: January 09, 2022, 08:42:45 AM »
Some of you folks are far too organized! :wink:
Online Ncdan
« Reply #24 on: January 09, 2022, 09:07:05 AM »
Good point mike, you think we should merge this topic with the “Crying Indian” one🤔😂
« Last Edit: January 09, 2022, 09:08:42 AM by Ncdan »
Online tparr
« Reply #25 on: January 09, 2022, 09:42:55 AM »
Beautiful.  :thumb:
My Winter project..
What are you building Chuck?  I had an RV-7 project that i worked on several years ago. sold it cause aviation is too expensive!
1969 Moto Guzzi Ambassador "A" model
2019 Moto Guzzi V7III
2013 Ural Gear Up
« Reply #26 on: January 10, 2022, 07:37:15 AM »
^^^^^It's an ultralight called a "Legal Eagle." Very open cockpit  :smiley: and will cruise around 60 mph. It's a bugs in your teeth flying motorcycle, really. When the pandemic hit, I thought I'd need *something to do* for at least a year. It has been that.  :smiley: :boozing:
The wings are spruce and 1/32" birch plywood with 1/8" birch ply spar webbing. Fuselage is .035" wall 4130 tubing. Every piece is fabricated.
I took the aluminum tail off so I didn't have to walk around it while fitting up the wings and struts in this picture.
Still need to mount the engine, design and build fuel and oil tanks, and all the myriad little things  :smiley: and cover. It's been an absorbing project, something to think about, and *something to do."
Albert Einstein
« Reply #27 on: January 10, 2022, 07:49:31 AM »
Oh, forgot. Guzzi content. I seriously considered using an inverted small block with a dry sump lubrication system, but it wouldn't make enough horsepower at 3500 rpm, the practical max for a propeller. I *have* a reduction drive from the Aero engine, but the small block and drive are too heavy for this airplane. All up weight has to be 254 lbs. or less for it to be considered an "ultralight," which the FAA considers not to be an airplane, so there are no restrictions, required inspections, licensing, etc. Just sit down, push the starter button, and roar around at 300-500 feet with that sweet little Verner put putting along burning 2 gallons per hour of automotive gas.  :smiley:
Albert Einstein
Offline yogidozer
« Reply #28 on: January 10, 2022, 11:11:36 AM »
That's Awesome Chuck! How do you attach the plywood to the wings?
I'll volunteer to be the test pilot  :grin:
« Reply #29 on: January 10, 2022, 12:17:49 PM »
Beautiful workmanship Chuck, your skill set is second to none!
