No there is not! At least, not on my bike. I used this point to drain the oil from the airbox. The breather system on this V7II is� one hose from each head to the frame under the tank� one hose FROM THE FRAME to the SUMP via an inline valve� one hose FROM THE FRAME to the AIRBOX� NO HOSE from the airbox to the sump (or anywhere else)All hose connections at the airbox, bar the one used for the hose from the frame, are blocked with little penises. As I said, I removed the left side penis behind the left cover to drain the oil from the airbox. There was over 200ml of oil and it soaked the air filterI have been using this bike since April and done nearly 8000km without something like this occurring.I lifted the rear of the tank to look but did not remove it completely. No crimped hoses were obviously apparent.
According to the manual I have to take it to the dealer to service the air filter. It's under warranty so I'll leave it alone but looking at the paper through the gap it looks very dry. Less than 3000km's on clock if that matters.
Meh, I don't think elevation has anything to do with it. Since new transmission is pressure fed I think this may be the cause, regardless of the oil amount. My theory is, that at high RPM's, pump is making just to much general pressure. I bet that if there would be only half of the oil in the gearbox it would still throw it out.
V7II Manual. It seems ridiculous to me too but that's how I read it.
Ummmm! The fact that there is an oil pump delivering oil to the bushings in the box does not mean that it is pressurising the box. To do that something would have to be added to the volume of the box, that doesn't happen, the pump just moves stuff around inside the cases.
It matters not what the owners manual says. The law of the land in the US is the Magnuson-Moss warranty act here: https://en.wikipedia.org/wiki/Magnuson%E2%80%93Moss_Warranty_ActPaul
I'm not getting the impression that applies to Mbug.
Don't know.... maybe, maybe not. Paul
It's probably the same here too.
Then what else did he mean by:Which was posted right after I explained how it is in the US?
Was curious about this, as it is an interesting -- and important -- point.It seems that Canada's provinces have equivalents of the Moss-Magnusen Warranty Act. See, e.g., http://blog.tdotperformance.ca/guides/warranty-battles-oem-vs-aftermarket/Bill
All I know is what he said, not what he meant. I don't make assumptions for the obvious reason. :Beating_A_Dead_Hors e_by_liviuPaulPaul
OK, as an experiment I'm going to delete the non return valve tomorrow and then Craig can take it away and flog the crap out of it and check the oil a very hour or so to see if any problems.Pete
