if you can't get the feeler gauge in, you need to rotate another 360 revolution until the D/S comes up again to compression stroke. Then adjust valves.
From my years of Latin (which of course I have used extensively since leaving school!)...D = Dextra (right) S = Sinistra (left)You'd also have seen this if you studied heraldry, and you'd see signs of it in most of the Latin languages (though most of them seem to have replaced the term for left with other words).
Maybe everyone discussing this is perfectly aware of this, but I don't want to leave it unsaid.D and S are timing marks that represent a flywheel/crankshaft position - i.e. that the PISTON on the respective side is at or near the top of its travel (whatever the specified ignition timing is before TDC for the model in question).HOWEVER, that DOES NOT MEAN when you see them that the flywheel/crankshaft is necessarily on the COMPRESSION STROKE.Half the time you see those timing marks the piston is at the top of the EXHAUST STROKE.You need to watch the valves to determine which one it is.Ok, I feel better now in case someone reading this didn't know that. Carry on.
Thumb over sparkplug hole tells if your on compression stroke.
That's only 1/2 the answer. So you are saying that when D or S appears it is on compression every 720 degrees.
So, are the 'D' and 'S' marks timing marks or TDC marks?
So, does that mean your question, (the second part), has been answered? As an aside FWIW, I found S and D the easiest to remember as "starter" and "distributor" as the distributor was always located opposite the starter, until they went away............... . But still, you get the idea.John Henry
The are TDC timing marks.
So, to be absolutely clear, the 'S' and 'D' are marks for TDC, NOT spark timing. Correct?
Would someone please shoot this thread in the brain?Thanks in advance.
