Six months or so after my V7ii seized up solid at a touch over 11,000 miles, I finally got her back home with a new engine courtesy (kind of) of Piaggio. When I looked over the paperwork, I noticed that the dealer that replaced the engine noted that Castrol 10-50 4T was used.Question for those who know better than I do: Is it okay to use 10-50 for the first 600 miles before the initial break in service? I have 10-60 on hand, but would hate to sacrifice 2 quarts of the good stuff if it’s not necessary. Looks like the flashpoint of the Castrol is 203C, vs. 230C for the Motul 10-60 I ordinarily use.Cheers to any Guzzisti who care to offer advice!
Just not that much difference. I would run the 10-50 for a couple thousand miles then change it to whatever I was going to keep running in it. Disclaimer: just what I’d do and not based on any scientific studies on motor oils👍
Why would they not use spec oil?
Mind boggling - to me, at least. This particular dealership was the one that Piaggio’s top rep recommended as the best one to get my engine replaced. At any rate, thanks for the feedback! Since it’s a brand new engine, I’ll run the 10-50 for the first 600 miles, then dump it and fill with 10-60.
Maybe I missed it but why did you need a new engine?
Wouldn't an new engine come with oil in it? Wouldn't the factory test start/run the motor just to make sure it works?
The V7 II bad crankshaft machining/thrust washer issue.
QUOTE: bad crankshaft machining/thrust washer issue.....OK...that's just WRONG for a modern bike!! Anyway, glad PIAGGIO took care of you...
Is it advanced metallurgy that calls for, what seems to me, very critical viscosity for break in and after? Except for 2 race engines long ago I've not changed break-in habits. Never a problem, be they small engines or over the road 170 to 600 hp diesels. 9 years ago I sold my 'company' car. Timely changes of oil, A' freeze, filters & spark plugs, 2 timing belts, 4 stock aluminum rims. Total miles, a Grosjean number of 696969.6. I drove it an extra 137 miles for an odometer picture. '03 Acura 3.2 Coupe 6 spd. R3~
Following up on the original post, I've not put about 40 miles on the bike after getting her home with the new engine.I noticed some wonky acceleration right off the bat: bogging, and occasional strong surging above 4K rpm. Mostly bogging though.I siphoned the old fuel out this morning (think I got most of it), and refilled with fresh 'premium' from Chevron, which here in California means 10% ethanol. My hope was that it would eventually smooth out as any gunk from the six-month-old (stabilized) fuel worked its way through. Toward the end of my second short ride today, it seemed to be clearing up a bit, but still had muted acceleration/bogging consistently in the 0-4K range. Strangely, there were a few moments in which it seemed to 'clear out' and momentarily surge for several seconds. Now I'm wondering if I have a problem with the fuel pump/filter (filter was changed to the all metal variety about 6K miles ago), or god forbid, the TPS, which I understand is inextricably connected to the ECU. I've reset the TPS a few times as well.Would mal-adjusted valves cause such symptoms?Can't catch a break. Curious what ya'll think and recommend...
Thanks for the advice, All. I checked the plugs, caps, oil level, air filter and airbox, and every connection I could think of. I have oil weeping from a cylinder head, and it’s throwing several codes as well, so I contacted Piaggio, and arranged to take it back to the same dealer so they can straighten everything out. Will report back when it’s (finally) sorted. Luckily my Griso, with 23k+ miles, has been unflappable while the V7ii’s been out of service!
I had similar symptoms after my engine replacement. The problem was caused by the latch on the plug of the signal wire to the fuel injector was not properly engaged. As a result the injector injected sometimes, and sometimes didn't.
I have been thinking about this.What about the good old spark plug cap problem.Has it been updated to the better caps and plugs.If it is shorting to earth intermittently it could cause what seemed to be bogging and surging.Briefly running on one cylinder will feel like that.Cheers, voncrump.
