IMHO, fuel injector cleaner is snake oil alcohol. Over the counter products do well at cleaning intake ports and valves. In my experience, the only way to clean an electronic fuel injector is an ultrasonic process like Asnu. http://www.asnu.com/
Agreed. Except they are mostly alcohol. Y�all hate alcohol in gas, right?Hunter
Fortunately with modern engines and fuel , carbon isn't much of a problem Dusty
Port fuel injected engines DO NOT have carbon build up problems. It is the GDI (Gasoline Direct Injected) engines that have carbon build up on the intake valves.
No offense, then you don't know the difference between the two. Not calling you stupid, just ignorant of how the two differ. I have two cars with port FI, one with 150K miles that the intake valves are perfectly clean (bore-scoped them). Have a GDI engine with 30K and already has buildup. I used the CRC GDI cleaner on this engine and valves cleaned up tremendously. Will use a can at every oil change from now on.
If you look at the SDS for MMO it really ain't no mystery.
So.....are you saying Marvel's Magic Mistery oil is superior?
Hi Chuck,I'm back! Do leave it with some seafoam in the tank to stabilize the gas, after running it a few miles. This has worked well for me when I had my fleet and could not ride everything all the time and some were down for work.Cheers bud,
I'm sharing this 'cause...uh... haven't the foggiest.
