Author Topic: 1/2 of a 850 LeMans engine ?  (Read 2481 times)
Offline Turin
    • crap and stuff
« on: June 01, 2019, 11:54:24 PM »
(* I picked this stash over 4 years ago, so a lot of stuff has been traded off and given / donated.)
When I picked up my Lemans SE racer project, part of the deal was that I take ALL of the Guzzi stuff. Three ford escape loads. Rusty eldo fenders, EV1100 crash bars, T-3 Convert tanks windjammer mounts etc.
With all the crap, I got a complete SP1000/G5 engine minus the carbs, The original Lemans 1000 SE engine sans heads (those are on the racer), an empty engine case, and this.
image upload
create image url
I noticed this piston had a dome on it while I was putting up the used barrels and pistons from my 850T.
Is this a 850 Lemans engine? If I remember correctly, Dave said it came from a race bike. ( maybe it crashed that's why the head and cylinder are missing? ) there is a EPA decal ( the company that used to make the 2-1 exhaust found on the Dr. John Race bike) on the 1 remaining valve cover.
The #s don't jive with the book I have.
« Last Edit: June 02, 2019, 03:28:55 PM by Turin »
1985 Sidlow Guzzi
1996 Triumph Daytona 1200
1996 Triumph Daytona 900
Offline Dukedesmo
Re: 2/3 850 LeMans engine ?
« Reply #1 on: June 02, 2019, 06:45:52 AM »
Someone more knowledgeable will confirm, but I'm fairly certain LeMans engine nos. start with VE.
That being the case, it looks to be from a bike older than '79 (the number is 'older' than my LM2).
« Last Edit: June 02, 2019, 06:53:11 AM by Dukedesmo »
Le Mans II
Ducati 916
Ducati M900
Offline earemike
  • Lurker
« Reply #2 on: June 02, 2019, 08:01:33 AM »
I’ve seen some pretty average stamping, lm 1/2 for sure
850 T3
850 LeMans
SP1000 Stucchi
V11 Ballabio
jwinwi
« Reply #3 on: June 02, 2019, 08:12:47 AM »
Didn't 850 LeMans heads have 6 mm threads for intake manifold attachment?
Offline larrys
« Reply #4 on: June 02, 2019, 08:25:38 AM »
What size is the intake port on the remaining head?
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
Offline wirespokes
« Reply #5 on: June 02, 2019, 09:12:02 AM »
Wow - what a haul!
Can't help with the identification, but do you want to sell the EV1100 crash bars?
Online RinkRat II
  • Lake Powell AZ
« Reply #6 on: June 02, 2019, 09:26:12 AM »
 Turin,
  Depending how tall the dome is will help identify the engine. Also the width's of the compression and oil rings. and of course diameter of the piston. Hope this helps.
      Paul B :boozing:
   Upon further checking VE designation is le mans I and II with the later version have plated cyls instead of iron.
                                       VF                     is lemans III
« Last Edit: June 02, 2019, 11:34:02 AM by RinkRat II »
Offline Turin
    • crap and stuff
« Reply #7 on: June 02, 2019, 11:37:58 AM »
The dome is much taller than what you would find on an 850 T-3 also 83mm bore. That's what caught my eye when I was putting away my old 850T pistons. I thought it might be an eldo block. I guess I could pull the head, but considering where this came from, who knows what was put together. None of this horde was treated with any iota of reverence.
1985 Sidlow Guzzi
Online RinkRat II
  • Lake Powell AZ
« Reply #8 on: June 02, 2019, 12:18:21 PM »
 The tallest dome of that lemans series is .389" but the 850 would be .178"
          Paul B :boozing:
Offline Turin
    • crap and stuff
« Reply #9 on: June 02, 2019, 03:24:55 PM »
Pulled the remaining cylinder head. Pretty sure the head is small valve. The cylinder bore is 83mm with a liner.
image upload
1985 Sidlow Guzzi
Offline PeteS
Re: 1/2 of a 850 LeMans engine ?
« Reply #10 on: June 02, 2019, 03:43:02 PM »
The piston looks like the one I took out my '76 LeMans. My serial number does begin with VE but its more than 100 higher. Even if the 1000s started with VF I wouldn't think they would start the numbers over again with 074xxx. My vote its an early 850 LeMans with half stamped VIN.
Offline Roy gardner
« Reply #11 on: June 02, 2019, 08:24:59 PM »
Piston; pretty confident it is LeMans, I have some like that, including 84mm, (+.020" OS)
Barrel; definitely not LM, it has had the iron sleeve fitted where the chrome was bored out. LM barrels have the iron skirt to the bottom.
Cases; maybe badly stamped, what is the case throat diameter?
You had me excited for a minute, I thought you might have a replacement for my damaged LM head! I have one with damage from a piston ring having smashed its way around the combustion chamber. But no, yours is a RH, I need a LH, & you recon yours is a small valve, bummer!
Interestingly, I recently had the "LM has 6mm inlet thread" theory busted. I purchased a brand new RH head which has "big" (medium) RB LM valve seats, deep combustion chamber, and bigger than standard LM inlet tract, but M8 inlet stub threads! I cant track it's origin, but would like a LH to match, or any LH LM head.
MGNOC L112
1973  850 GT (sold 1979)
1974  160 Stornello (bought new 1978)
1972 V7 Sport, (bought 1979, still running strong)
1977 Convert (bought 2009)
1974  850T (ComposT, pawned to buy Vincent parts!
1985? LM 1000 (saved from a savage, has become hotrod Convert)
Offline Turin
    • crap and stuff
« Reply #12 on: June 02, 2019, 09:59:39 PM »
Case wasn't bored. I measured 3.7". Diameter of sleeved cylinder matches a nos T3 barrel and the two chrome 850T barrels that I recently replaced.
If this is a lemans engine, then I'd like it to go back with its original frame. If that's not around, maybe a lemans that has an incorrect motor.
I don't see myself doing any kind of project with this, especially after the 4 years it took to do the lemans se.
« Last Edit: June 03, 2019, 12:28:31 AM by Turin »
1985 Sidlow Guzzi
Offline 5154guzzi
    • Team Subtle Crowbar
« Reply #13 on: June 03, 2019, 01:58:56 PM »
Turin,
   The roundfin stud pattern of the VE LeMans 850 is smaller than that of the squarefin VF prefix ( 850 LeMans III ) pattern.  You have a 850 roundfin Lemans case or those cylinders and heads wouldn`t fit.
Offline Turin
    • crap and stuff
« Reply #14 on: June 03, 2019, 09:23:44 PM »
Yeah, I've got no intention of putting any heads in this. Might make a coffee table out of it. :evil:
1985 Sidlow Guzzi
Offline Roy gardner
« Reply #15 on: June 05, 2019, 04:56:10 AM »
Here is my LM II 1979?? case marked remarkably similar. Barrel throat measures 3.7" or 94mm. Spada cases measure 3.74" 95mm.
Mine will get 88mm cylinders with  the correct high dome slugs then a Convert cam ground to B10 spec to drive a Convert trans.  Yours will look lovely in the lounge with a glass top on it   :laugh:
MGNOC L112
Offline Turin
    • crap and stuff
« Reply #16 on: March 03, 2021, 11:29:01 PM »
opened up the timing cover and found this.
Found out this is from a 77 Lemans that was raced locally. there is some kind of cam in it, andit had a lightened flywheel which I swiped and slapped on my 850T  :grin:
1985 Sidlow Guzzi
Offline lucky phil
« Reply #17 on: March 04, 2021, 12:50:34 AM »
Yep, needed on a 4 stroke or they don't run.
Ciao
Offline jacksonracingcomau
« Reply #18 on: March 04, 2021, 02:58:21 AM »
Avoiding contention
If you don’t want them, pm me
Offline Desmo
« Reply #19 on: March 04, 2021, 07:28:26 AM »
There were lots of early Le Mans 850 motors that should read VE the were stamped POORLY and looked like VF  :shocked: The lower part of the E could be seen under close inspection.
1976 Le Mans
2003 BMW Boxer Cup
1985 K100RS EML Sidecar
1994 R100GS
2015 Yamaha Super Ten
Offline Turin
    • crap and stuff
« Reply #20 on: March 04, 2021, 11:07:59 PM »
Had a buddy verify, It's a 77 lemans motor. I'm going to build the sucker as a back up.  I have a set of NOS ASSO pistons and some really nice original barrels. Going to modify a set of small valve heads.
« Last Edit: March 09, 2021, 09:39:34 PM by Turin »
1985 Sidlow Guzzi
