Author Topic: V7 II idle problem  (Read 558 times)
Offline Bajadera
V7 II idle problem
« on: March 15, 2024, 01:33:36 PM »
I have 2015 V7 II Special with only 8000km that has cold idle problem
The cold engine starts fine but idle revs are very uneven going up and down ...
Engine doesn't want to pick up revs and sometimes dies
It starts immediately and then runs fine
When the engine get normal working temperature it runs pretty well
The spark plugs are completely new
What could be the problem?
Where to start?
Thank you
Breva 750 ie 2004
Vespa P125X 1981
Vespa PX125E 1993
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: V7 II idle problem
« Reply #1 on: March 15, 2024, 01:39:41 PM »
What condition is your air filter? Have any moisture clogging it?
Current: ‘16 Guzzi V7 II Stone, ‘78 BMW R80/7
Previous: ‘15 Ural Gear Up, ‘77 Kawasaki KZ400 Special, ‘78 Honda CX500S, ‘80 Honda CX500D, ‘11 Suzuki TU250X
Offline blu guzz
  • Loves to ride
« Reply #2 on: March 15, 2024, 01:50:07 PM »
the plug caps are very delicate on that model, were you very careful when you removed and replaced them?  If they are damaged, they could cause an ignition problem.
Blue Guzz
Offline Bajadera
« Reply #3 on: March 15, 2024, 01:51:37 PM »
Not a sign of any moisture...
It is dry like desert... :cool:
Breva 750 ie 2004
Vespa P125X 1981
Vespa PX125E 1993
Offline Bajadera
« Reply #4 on: March 15, 2024, 01:53:27 PM »
The caps looks OK to me
I didn't notice anything wrong with them...
Although...I will check them again tomorrow
Breva 750 ie 2004
Vespa P125X 1981
Vespa PX125E 1993
Offline Vagrant
« Reply #5 on: March 15, 2024, 03:30:34 PM »
In the US there was an updated map for that bike.
Smartest thing to do is put on a Beetle map.
2016 V7II, 2017 V7-III Blue special, 2022 V85 the fast red one! 2016 650 Versys
Offline sign216
« Reply #6 on: March 15, 2024, 04:20:12 PM »
Generally, loose valve settings make for a better idle.  That might not be the answer, but it would help.
Refresh my memory, does this year have the fast idle lever for cold engines, that pushes the throttle open slightly?
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline Bajadera
« Reply #7 on: March 15, 2024, 04:22:23 PM »
No
No fast idle lever...
Breva 750 ie 2004
Vespa P125X 1981
Vespa PX125E 1993
Online Tkelly
« Reply #8 on: March 15, 2024, 04:38:37 PM »
Our dealer installed the new map and it ran great,original map not good.
Offline mechanicsavant
« Reply #9 on: March 15, 2024, 04:52:19 PM »
I had similar issues with my 16 Mk. II . I believe it’s going into closed loop too soon . More miles help . As does a beetle map . I went in a different direction . As I’m not terribly computer skilled I went with adjustable O2 sensor “spoofers” from  AF1 racing & gutted the exhaust of the cat converters . That said the bike in only for off road use ( wink wink ). It runs much better & no cold start issues . AS usual Your results may vary!
Online Dirk_S
« Reply #10 on: March 15, 2024, 07:47:49 PM »
I recently had a similar issue with idle—seems to start up fine, but then after a moment would be a bit erratic—a little up, a little down, and sometimes down low enough it shut off. After warming up it would be fine. The kicker—I have a beetle map. It’s only ever happened so far when it was pretty cold out. One time I found my air filter pretty wet due to some rainy days causing the seat to soak up and leak water down the front. I experienced the problem a few times, but it’s not constant, hence why I thought it might be moisture.
Maybe it’s in the fuel? How long has the fuel been in the tank? Is it fresh? Is there a vacuum that’s perhaps causing the fuel pump to not draw appropriately? Pop open the gas cap once and try running the bike after?
Online GuzziOrDeath
« Reply #11 on: March 15, 2024, 08:02:21 PM »
Check for oil residue in the airbox. If oil gets into the MAP sensor or idle stepper ports, all kinds of weird things can happen.
Offline slowmover
« Reply #12 on: March 15, 2024, 08:24:05 PM »
Only 8000km on a 2015?
Offline Bajadera
« Reply #13 on: March 16, 2024, 12:56:15 AM »
Yes
Only 8000km...
The previous owner just didn't ride it
The bike is like brand new from the shop
Breva 750 ie 2004
Vespa P125X 1981
Vespa PX125E 1993
Offline Bajadera
« Reply #14 on: March 16, 2024, 12:57:46 AM »
I will check that for sure
Breva 750 ie 2004
Vespa P125X 1981
Vespa PX125E 1993
Offline sign216
« Reply #15 on: March 16, 2024, 07:03:06 AM »
No
Gang, so Guzzi added an "electronic" fast idle when cold, like a modern car?
That's one less thing to do when starting, but I kind of like the manual approach.  Of course that's a slippery slope.  Soon, we'll go back to a manual ignition advance, etc.
Joe
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
« Reply #16 on: March 20, 2024, 07:23:29 AM »
Yup , both my small blocks have the “fast idle”as part of the program . My V7/850 is way better than the MkII , no issues at all . The MkII is better once sorted also .
« Reply #17 on: March 20, 2024, 09:04:08 AM »
My 2015 started to do that.  Turned out the battery was on it's last legs.  A battery load test would help confirm or eliminate that issue.  If it's the OEM it may be at the end of it's service life.
