I've read a few threads about adjusting the valves on my V7II and am having trouble getting the bike into 6th gear to facilitate spinning the rear wheel to find TDC.I cant seem to get it past 3rd gear.Is there some trick to this?Also,when re-torquing the head nuts at the first service interval,is it necessary to loosen them first,then tighten them to the specs?
Ummmm... No?
OK. On my 2013 V7 I can take off the alternator cover and turn the bolt. Not possible with V7ll or V7lll? How about V9s? Inguiring minds want to know.Seems like a lot of new guzziti are learning to wrench on their new bikes. Good on 'em. Dave Galveston
For the record, the last year of the 1TB V7 mkI and all years of the V7II, V7III, and V9 use a wet alternator (runs in engine oil) so you can't access it to spin the crank.
Watch this, it might help. https://www.youtube.com/watch?v=hSO0dphXx-w The procedure is nearly identical for big and small block engines.Hunter
Ummmm... Actually, yes!
Stokes, it's not easier to SPIN, but easier to spin with some precision.In lower gears the engine spins a bunch of times for each spin of the rear wheel, that's what makes more thrust.In higher gears the engine spins fewer times for each time the rear wheel spins so it's easier to align the crankshaft where you want it.
I believe it was your post I was refering to about this.Why does my manual say to open the front of the engine and turn the crank there? Not that I'm doubting you,and I'd rather not remove the front of the engine.The manual explains this way of doing it in a section about completely disassembling the engine.Is there something I'm missing?
Stokes, it's not (so much) easier to SPIN, but easier to spin with some precision.EDIT for clarity - yes it's both - but I think the more important point is the precision.In lower gears the engine spins a bunch of times for each spin of the rear wheel, that's what makes more thrust. (EDIT) So mechanically the engine has the advantage over the wheel/bike.In higher gears the engine spins fewer times for each time the rear wheel spins so it's easier to align the crankshaft where you want it. (EDIT) So mechanically you have the advantage of turning the wheel further for less movement/effort on the motor.
It's always easier to spin the back wheel to rotate the engine.
Kevin... The original question was, why can't I get the bike higher than 3rd gear by rocking the wheel and changing up by hand, was it not? And that was what my response was to.
BS Kev.
It is easier physically to spin the crank by turning the rear wheel by hand, if you are in a higher gear, and the crank turns slower for a given rear wheel speed in top than first, so therefore you can do it more accurately in sixth. Are you going to dispute this?
And why can't he get it past 3rd? Obviously if he went for a ride and selected sixth the and pulled the clutch and rolled to a stop, it'd be in sixth, so why not at home on the stand?
this is one more case of an accident waiting to happen. he needs to get some help from a competent mechanic or take it to the dealer.
Kevin... The original question was, why can't I get the bike higher than 3rd gear by rocking the wheel and changing up by hand, was it not? And that was what my response was to. Naturally it's better in a higher gear because you're using the taller ratio of top gear,to your advantage, however turning the crank by using the front nut is "nicer".
Question regarding that video. When finding TDC, you don't see how the rear wheel is turned, but there is a very "ratchety" , "click, click, click" as the piston comes up to TDC in little tiny steps. What is going on there? When I turn the rear wheel it is a very smooth motion and the piston gradually moves up, but not in little precision steps like that. How did he do that???
