Author Topic: No acceleration passed 3rd  (Read 606 times)
Offline 850brian
« on: April 17, 2024, 09:04:15 AM »
Hello all, I have a 1975 850t that I am restoring. I thought I had it road ready; however, it seems something is not quite right. Just got back from a test drive and it has decent power up until about 40mph and about 3rd gear and then it seems that no matter how high the rpms are there is no acceleration like at all. Any thoughts?
Re: No acceleration passed 3rd
« Reply #1 on: April 17, 2024, 09:12:29 AM »
Were the carbs cleaned thoroughly?  Did you set the ignition timing with a strobe?
2022 V85TT Guardia d'Onore
Offline 850brian
« Reply #2 on: April 17, 2024, 09:37:16 AM »
I did not set the timing with a strobe and the carbs were cleaned rather thoroughly.  Additionally I have noticed a rather significant oil leak coming from the hole just above the oil drain plug. Any ideas?
Offline Tkelly
« Reply #3 on: April 17, 2024, 09:45:02 AM »
Clutch slipping?
« Reply #4 on: April 17, 2024, 09:54:00 AM »
Of course it is either the front seal of the transmission leaking, the rear main engine seal, or both.  There are no easy fixes.  I think you know what the next steps will be.
Tkelly's question is valid.  Is the clutch slipping?  Could be oil soaked plates.
« Reply #5 on: April 17, 2024, 09:55:46 AM »
Rear main seal leak. Rear main bearing carrier gasket. Front trans seal. Oil on the clutch plates can cause them to slip? Leak can also come from the breather hoses if the clamps are not tight or the hoses are bad.
Offline 850brian
« Reply #6 on: April 17, 2024, 10:50:57 AM »
Thank you for the reply, it doesn't seem that the clutch is slipping. I will take a look at the breather hoses with fingers crossed.
Offline 850brian
« Reply #7 on: April 17, 2024, 11:12:41 AM »
Unfortunately it looks like I also have oil leaking out of the inspection plug
Offline 850brian
« Reply #9 on: April 17, 2024, 11:33:38 AM »
Yeah just had to trailer it home. It lost all acceleration at any gear at any rpm. Wish me luck
« Reply #10 on: April 17, 2024, 12:01:51 PM »
I would check your timing, maybe it moved. I remember you asking about timing last.
Offline pehayes
« Reply #11 on: April 17, 2024, 01:16:28 PM »
After you set the ignition timing correctly, I would also check for proper centrifugal advance of the spark under higher rpm.  If the advancer gets dirty/stuck, it will start and idle just fine.  It will accelerate at low rpm just fine.  It will feel like hitting a wall when  you get to higher speed and higher rpm.
Offline Scout63
« Reply #12 on: April 19, 2024, 07:08:36 AM »
It sounds like two separate problems.
Oil in the clutch housing could be rear mail seal, maybe the crank vent tube came loose?  If it is gear oil leaking then front trans input seal. Either way a crab is coming.
Loss of power would be spark or fuel. If it were just high rpm then maybe jetting.  But there is a total loss.  I would check power and ground wiring to the coils and distributor. Put a voltmeter on them and start wiggling wires all the way back to the fuses and switches.
Ben Zehnder - Orleans, MA USA
Offline 850brian
« Reply #13 on: April 19, 2024, 07:54:58 AM »
I will look into this. Seems exactly like my symptoms.
« Reply #14 on: April 19, 2024, 07:07:18 PM »
If you are in third about 4500 rpm and go to wide open and the rpms increase without acceleration, it’s due for some clutch work. Once they start to slip, they are done for.
Offline brider
« Reply #15 on: April 20, 2024, 08:58:25 AM »
I agree with John A, symptoms say clutch slipping.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
Offline 850brian
« Reply #16 on: April 21, 2024, 01:15:33 PM »
So I need to get a new clutch and probably replace the main seal?
Offline brider
« Reply #17 on: April 21, 2024, 01:52:55 PM »
I would think new friction plates and a fix to whatever is leaking to contaminate the clutch. Might not know fer sher until you pull the tranny.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'72 Red Eldo
'74 White Eldo LAPD
'06 Gas Gas EC300
'86 LM IV
