Author Topic: Jetting for obscure small block  (Read 587 times)
Offline Bazil
« on: December 01, 2022, 03:41:58 PM »
So, I am the proud owner of an obscure small block, a V40 Targa. Made for the Japanese, Greek and maybe French markets ? It's a 1991 two valve head engine with a short stoke Monza piston I believe 74 x 45 stroke.
It's ready to get on the road but I'm having trouble with a hanging idle. Tried the usual things - cabling routing, choke sealing etc. Carbs are PHBH 28s, which typically are used on V50s and Monzas. Found the carb needle was a bit rough near the top of the shaft, so i polished it up, but it's still a little roughened. OK, maybe I should replace the needle ( and jet). That's where it gets interesting. The needle is an X24. Haven't checked  jets yet. I do not have a manual for this precise model and on This Old Tractor I can only find manuals for V35 / V50 models, two and four valve. None of these use an X24 needle.
So my questions: does anyone have a manual for this thing, or at least has a V40 Targa and can confirm jetting ? I'm thinking maybe the jetting is to suit Japanese emission requirements or maybe the oddball engine just had oddball jetting. If I'm replacing needles & jets etc I'd like to be using the correct ones.
Not expecting to have much success with my query given the obscurity of the model, but it's worth a try.
Thanks in advance !
1986 Lario ( long gone, still missed)
1985 Mark IV Lemans ( Gina)
1991 V40 Targa ( L'il Jeannie)
1962 Royal Enfield Crusader Sports
Re: Jetting for obscure small block
« Reply #1 on: December 01, 2022, 04:34:33 PM »
OK X24 is in size
cylinder---2.50
tip--------1.00
taper starts 30 up from tip
For reference the V50 used an X6
cylinder---2.50
tip--------1.20
taper starts 26 up from tip
V35 uses an E needle
E27 is
cylinder--2.42
tip-------1.25
taper starts 18 up from tip w/260 atomizer    V50 & 65 is 268 atomizer
Only one I could find w/ X24 is the V35 Imola II
X24--2nd notch
112--main jet
45---pilot
262 --atomizer
https://guzzitek.org/gb/ma_us_uk/V35I2_V50M2_V65L_Atel(GB).pdf
Hope this helps
« Last Edit: December 01, 2022, 04:48:30 PM by guzzisteve »
Offline Bazil
« Reply #2 on: December 01, 2022, 05:01:25 PM »
Awesome ! Thanks for the quick reply. Great reference point.
I hadn't thought to look at the four valvers. Stylistically it matches the Imola II, but with 18 " wheels. It didn't occur to me that they might share carbs.
Thanks Steve
« Reply #3 on: December 01, 2022, 05:11:40 PM »
I'd be making sure the ignition advance mechanism is moving freely. Could be why the idle is "hanging".
Online pehayes
« Reply #4 on: December 01, 2022, 05:19:24 PM »
+1
Notorious.  Advancer mechanism is up front under a partial plastic cover.  Front wheel throws road debris right at it.  Has to be cleaned and lubricated more than other distributor based Guzzi models.
Offline Bazil
« Reply #5 on: December 01, 2022, 06:07:26 PM »
Thanks Charlie & Patrick;
no problem with sticky advance - it has the Motosplat ignition. Is that a good thing or a bad thing ?
Offline sign216
« Reply #6 on: December 01, 2022, 06:09:33 PM »
Yahoo formerly had a good Smallblocks group.  When Yahoo groups folded I recreated the group, with limited success.  See  https://groups.io/g/Moto-Guzzi-SmallBlock
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
« Reply #7 on: December 01, 2022, 06:28:16 PM »
After I wrote that, I wondered if it was pertinent. Could be a vacuum leak. Are the rubber sleeves between carbs and manifolds in good condition? Gaskets between the manifolds and heads?
« Last Edit: December 02, 2022, 08:14:30 AM by Antietam Classic Cycle »
« Reply #8 on: December 02, 2022, 07:18:35 AM »
"I know nothing.."  :smiley: but I haven't read anything good about them.
Albert Einstein
Offline FarmallA
« Reply #9 on: December 02, 2022, 08:38:39 AM »
Tight valve clearances?
Steve
FarmallA
Offline rogerlse
« Reply #10 on: March 01, 2023, 07:51:13 PM »
 Hi there . I am in New Zealand and am running a v40 2 valve motor in a Imola 11 frame. The jettin I'm using is main jet #120,needle x24 2clip, spray nozzle 262 Ce,pilot #40 , choke jet #60, slide #30 fuel screw 3/4 of a turn. Standard air cleaner. So far had about a 1000 km. All good.
1974 Benelli 250 2C
1979 Moto guzzi V50 11
1985 moto Guzzi V35 Imola 11
