I know this isn't what your looking for but I take the valve covers off then remove the sparkplugs and hit the starter button and see if the rockers are oozing oil.
One question , what are you gonna do if it turns out the Norge is only making 10 LBS of oil pressure , or 100 LBS ? Dusty
Start an oil thread? Who will be the first to suggest 10 psi per 1000 rpm...
A good way to add some anxiety to your riding day is to put an oil pressure gauge on your Guzzi.Don't ask me how I know this....:-)
One day the Kid, who is a *very* good mechanic, thought it might be a good idea to find out what the oil temp was running in his Sport. He called MG Cycles, about one of the temperature dipsticks and Gordon said, "Sure, I'll sell you one, but you probably won't like what you see. Then, what are you going to do about it?" That Gordon Shirley puts the hard sell on a guy..The Kid said, "Ok, I get your point. Never mind.."
I'll second that! My EVT on a hot day at idle shows about 5 ish pounds on the gauge. But cold start up is about 60. This is with a cheap electronic sender gauge, might be different with a regular gauge. I went electric because of warnings of the oil line to the gauge breaking and hot oil spaying all over.Rinkrat's test gauge looks good. What about an automotive gauge that would normally be installed. The kind you find for about $10 at a parts store. Might be the cheaper way to go and just use it for your test and then remove. OR if you decide to keep it on the bike, I'll dig up the info on a really easy to install splitter so that the light works as well as a gauge.Tom
The simplest would be to remove the oil pressure sending switch, install an appropriate adapter or fitting and install a hose with gauge like this.... I would think at startup you should see 40 to 60psi. Less at idle after it warms up. My $.02 Paul B
Yup...and she has done pretty good service hasn't she !
So your trying to find out if it's an indication problem or an actual pressure problem. You got to trust your machine to go the places that you do. What's young Pete say? Maybe you can drag him into this..
Wasn't trying to sound snarky , I'm simply always curious about why we are asking a question . Dusty
As RinkRat suggests easiest is to use the switch take off on the crankcaseI'd also measure temp too, I use one them dipsticks everybody laughs at, but the temp affects viscosity and that can make a dramatic difference to the pressureI know because I'm hunting down a presure problem on a HiCamOn the older bikes you should see about 70-80 psi on cold oil at fast idle, I'd use a 100 psi gauge Again on the older bikes the thread is 12mmx1.5 as I recall
He won’t need an invitation and we have spoken about it.
I'm not familiar with Norge engines, no experience so I'm learning now.Its been my experience as well running a pressure gauge that I would worry about it and that would distract me from the task at hand ie: trying not to wad it up
My logic in fitting one was twofold :The early Tonti tank has a space where the Ignition key switch lives and that ends up by scratching the tank even if you use a fob.....so I relocated the switch a long time ago and was left with the space for a gauge....and if the pressure is getting dangerously low I'd like to see by how much and not just rely on the red light which I still have . It doesn't freak me out and at least I ca see what the pressure gauge reads and act accordingly.At revs mine reads 4 bar which is exactly where the pressure relief valve cuts in so I'd guess the Norge will read at 5 as I think the valve cuts out higher on those.The parts book would confirm that.
