Well, I pulled the valve cover and took pics, even though I'm not entirely sure what flat versus roller looks like, from this angle. The pics look like they could be rollers, but again, I've not found any detailed diagrams of the comparison to make that judgement. Fingers crossed; can it be discerned from this pic whether it's a flattie or a roller?russian image host
Is the lubing of the swingarm bearings and rear shock linkages done via zirq (sp?) fittings, or does it require disassembly?
With regard to the Power Commander; never used one---is it a big deal to remove, or just unplug it from the system? I do know that my unfettered 2-valve 1200 Guzzis were much better mannered than my 4V Griso is now (though I did use a Staintune pipe on the2-valvers---glorious sound), and so I'm inclined to take the chuck-the-Power-Commander advice. Concerning the exhaust, I have two choices (without buying something else). The Systemi di Scarico underslung canister that's on it now, or the Termignoni that I was told was a factory upgrade. I don't have the oddball exhaust that's stock on the Griso.
Can we get a picture of this exhaust? If you can't post one up just send it to me and I'll do it for you.motomoda.roper<at>gmail.comPete
Here are pics of the exhaust. Pete referred to the 'pretzel'; is that the O2 sensor?With regard to installing a map, I can't do that without the Power Commander, correct?I went out and looked at the Termignoni pipe; I don't think there's a baffle in it (I had assumed that it did not have a removable baffle). No surprise; the guy I bought it from likes LOUD.I'll go Google GuzziDiag to see what that's all about.
Here's the Termignoni, and it appears to me that the pretzel is included? I'll do some studying at GuzziDiag (didn't even know it existed), and probably revert to the Termignoni, with the proper already-developed mapping. I'll think about it. I actually like the look of the underslung exhaust, but I better like something that's functioning properly (and is not pretty loud even with the baffle in). Might have to shop around to find a baffle for the Termignoni. Thanks for all the advice; this is a great forum!
Actually, the Griso does seem to have good lowend/midrange torque, but I can't yet compare it to how it would be with a different setup. I'm not a revvy type of rider, and have probably not run up past 5000 RPM yet. The Sistemi di Scarico canister does have a baffle inserted in the end of the canister; I assume that's what is being referred to as a DB Killer? Or is a DB Killer something else? Beetle said something about maybe installing one on the end of the pretzel, and I'm not sure how that would work, with the baffle I have. The Sistemi is kinda loud with the baffle in, but was insane with the baffle out.
I downloaded the GuzziDiag software and ordered cables from Lorelen (sp?). It sounds like the general consensus is that I'd be better off withe the Termignoni pipe and proper mapping (and DB Killer), after ditching the PowerCommander? Or possibly the Sistemi/Quad D canister attached to the pretzel (which might look a little wierd, not sure)?Gotta do some more studying in the GuzziDiag section
Good on yer for having a reasonable attitude. I DIDN'T have a reasonable attitude, which often happens, and Guzzi's attitude toward their very clear and universal SNAFU pissed me off bad enough that I didn't care if it was "worth it", if they were going to do me that way, I was dumping the bike in bits to make other Stelvio owners happy with cheap spares .... !Worked out OK though.Lannis
