Author Topic: Swanee on EV  (Read 889 times)
Offline johnwesley
Swanee on EV
« on: May 14, 2022, 08:01:30 PM »
Probably the best handlebar fairing ever made if you care more about function over form. A friend gave me the fairing years ago. I put it away knowing I would use it one day. Today was the day to work out a install plan. Not to bad if you have mounts and a 7/8 handle bars, but this ev has 30mm. Plus I wanted to make it easy to swap back to a smaller shield and keep this one for multi week touring and winter. Plan is to use the factory mount points which will help ease of replacement and keep clamps off the bars.
Fist order was to make a mount that was missing.  You’ll notice the new one is longer which will come in handy. I ended up making two long rods.
Once happy with the lengths and clear on how I was mounting it was time for more shaping. Lots of heat and hammering
Make sure to leave it a bit thicker thanks needed so when you polish out the hammer marks and clean the edges it’s still strong enough.
Once the mounting hole was drilled everything cleaned up nice and seems to work well.
Got the height worked out so the hand grips are covered. With the bars raised up the fairing had to set up taller than normal. The bottom mounts are just stap and the need some love before they are ready for prime time. That will be work for another day.
The windshield will need to be cut down, most likely replaced. I put a gustafsson on dads and it is much thicker which adds to the rigidity of the fairing. Looks good on the bike as well. We went with a bronze tint.
« Last Edit: May 14, 2022, 08:03:51 PM by johnwesley »
2009 cal-vin
2003 cal ev
1985 lemans 1000
Offline flower_king001
Re: Swanee on EV
« Reply #1 on: May 15, 2022, 07:47:16 AM »
best performing fairing/shield on a Cali-bike. I have one on my 96 Cali i but plan to sell the bike. If and when I do I'll remove the Swanee and put it on  my EV that has a oem Sport Shield.
Function over looks!
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Online Wayne Orwig
Re: Swanee on EV
« Reply #2 on: May 15, 2022, 08:21:11 AM »
 :boozing:
Looks good.
I was able to locate some 30mm clamps that I was able to adapt. I like the way you have it. I would only worry about not being able to adjust it a little.
Offline johnwesley
Re: Swanee on EV
« Reply #3 on: May 15, 2022, 11:47:29 AM »
:boozing:
Looks good.
I can still adjust up and down and change the angle with the lower brackets. One I’m sold on the fit then I want it to be fixed so as I mount it and take it off the fit doesn’t change.
2009 cal-vin
2003 cal ev
1985 lemans 1000
Re: Swanee on EV
Online Chuck in Indiana
Re: Swanee on EV
« Reply #4 on: May 15, 2022, 05:05:49 PM »
Purty is as purty does.  :smiley: I have many miles behind one, and as far as I'm concerned, it is the best handlebar fairing ever.  :thumb:
Albert Einstein
Online maquette
Re: Swanee on EV
« Reply #5 on: May 19, 2022, 04:20:02 PM »
I'm with Chuck on this one. Best fairing I've had the pleasure to ride behind.
Oriental, NC
'98 V11 EV
Offline steven c
Re: Swanee on EV
« Reply #6 on: May 19, 2022, 08:43:19 PM »
Someone say Swanee? :thumb:
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline John Ulrich
Re: Swanee on EV
« Reply #7 on: May 20, 2022, 07:41:12 AM »
Eagan, MN & Scottsdale, AZ
MN MGNOC Rep  L#800
Online ccoli
  • What? Me Worry?
Re: Swanee on EV
« Reply #8 on: May 20, 2022, 10:04:02 AM »
And here's the exact same faring on my, new to me Bassa.  Saddlebags and throttle covers were from JU's bike as well.
Wisconsin MGNOC Rep
03 EVT/EML hack, 99 Bassa, SPIII, 3-78 Robins, 75 T3, 74 Eldo, 32 Sport15, Ambo custom.
Offline steven c
Re: Swanee on EV
« Reply #9 on: May 20, 2022, 03:08:36 PM »
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Online Vagrant
Re: Swanee on EV
« Reply #10 on: May 20, 2022, 04:37:24 PM »
The pretty red and white from 2001.
2016 V7II, 2017 V7-III Blue special, 2022 V85 the fast red one! 2016 650 Versys
Offline John Ulrich
Re: Swanee on EV
« Reply #11 on: May 22, 2022, 02:57:39 PM »
Parts never die, they just continue to circulate!
Those bags have a lot of mink oil soaked into them!   :thumb:
MN MGNOC Rep  L#800
Offline inditx
Re: Swanee on EV
« Reply #12 on: June 17, 2022, 08:42:09 AM »
Saweeet Swanee & EV of course!
inditx
inditx
This is the day.....
