Author Topic: Clutch Timing Marks ?? NGC  (Read 454 times)
Online Canuck750
« on: August 12, 2022, 06:03:08 PM »
Has anyone seem clutch basket timing marks to align with the primary gear? This is off a mid 60's Benelli 250 egg motor (4 stroke single)
The crank to cam gears have the typical timing marks
Manual makes no mention of timing the clutch basket but its straight forward to align, just wondering if anyone has seen this and a reason why?
Offline Bull Tahr
    • My YouTube channel
Re: Clutch Timing Marks ?? NGC
« Reply #1 on: August 12, 2022, 07:38:58 PM »
No answer for you I'm afraid, but very curious also to find out why................ .. :popcorn:
Utrinque Paratus
On the Face: Dusty Visor Motorcycles
Offline RinkRat II
  • Lake Powell AZ
« Reply #2 on: August 12, 2022, 08:19:22 PM »
       Is the ignition or tachometer run off of one or the other?
          Paul B  :boozing:
« Reply #3 on: August 12, 2022, 08:34:45 PM »
Could be that it shakes less. Rotating mass counter acts rotating mass, just a guess. I just want to fix the moped, ha ha. Back to work.
Offline Mike Tashjian
« Reply #4 on: August 13, 2022, 06:35:04 AM »
Machined gear sets matched with marks to run better?, quieter?, longer?  Not something I've on small motorcycle engines.  But easy enough to line up and play along.
Offline berniebee
  • 2020 Board Donor
« Reply #5 on: August 13, 2022, 07:58:30 AM »
Perhaps the marks on the clutch basket have nothing to do with the primary gear, but are for assembly of the clutch. Does the clutch basket cover (pressure plate) have marks?
« Last Edit: August 13, 2022, 08:03:49 AM by berniebee »
Offline n3303j
  • Ron Cichowski
« Reply #6 on: August 13, 2022, 09:12:52 AM »
Magneto ignition and the magnet is in the flywheel?
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online Canuck750
« Reply #7 on: August 13, 2022, 11:00:16 AM »
The bike has a magneto running off the crank shaft. There are no marks on the pressure plate.
Still a mystery…..
« Reply #8 on: August 13, 2022, 12:49:31 PM »
Perhaps they thought "why not have marks, it will get put back in the same place then, that can't hurt"
At the very least it causes you to be more careful eh!
Half a V9 Roamer
