Author Topic: California Stone 1100 bin file  (Read 700 times)
Offline flycaster
« on: March 23, 2024, 04:09:21 PM »
Hi to everyone, I bought a used California Stone 1100. I’m searching for the original bin file for the 15M ECU equipped on it, because the previous owner confessed me that he had re-mapped it.
Thank you
Re: California Stone 1100 bin file
« Reply #1 on: March 23, 2024, 05:10:24 PM »
Guzzi changed mapping like their shorts go by year is better. May be the same as a Jackal.
I have a California bin  15M C3 61600.381.01 501604710400 , don't know what it's from.
What does the tag say on outside of ECU?
What XDF file are you using? TunerPro or other?
« Last Edit: March 23, 2024, 06:05:40 PM by guzzisteve »
Offline s1120
« Reply #2 on: March 24, 2024, 06:27:43 AM »
How does it run? I had terrible running issues with my 02 stone when I got it, and tried a few different maps till I got one that was close. If its running well, I would just work with what you have. SOme of the stock maps were pretty bad.
Paul B
Offline Caffeineo
  • Guzzi B00b
« Reply #3 on: March 24, 2024, 07:31:00 PM »
Get a Beetle map and ride.  :bike-037:  https://inner.forumotion.com/f12-beetlemaps
2022 Moto Guzzi V85
2018 Husky 701
2023 Husky TX300
Offline elrealistico
« Reply #4 on: March 25, 2024, 08:32:54 AM »
I am interested in a map to try in my 04 EVT, have some popping on decel when warm, have checked for leaks, not seeing any cracks on hpipe or crossover. Looking thru the Ancient Wisdom here, pauldaytone had some maps, that some folks used, is he still active on WG?
2018 V7III Special
1978 T140V Bonneville
2004 EV Touring
« Reply #5 on: March 25, 2024, 09:53:57 AM »
Popping on decell usually means idle mix is a bit lean. Go up a few numbers on idle mixture.
If Paul isn't here you can find him on the Ghetto.  I looked, he is still here.
« Last Edit: March 25, 2024, 09:57:36 AM by guzzisteve »
Offline flycaster
« Reply #6 on: March 25, 2024, 04:12:12 PM »
Hi! I’m using the latest XDF file available on the official guzzidiag web page for the California 1100 Stone (version 2.52 if I remember correctly)
The ECU is a 15M, and I think there are no differences between Stone and Jackal.
Would you like to send me the original bin file?
Thank you.
Offline flycaster
« Reply #7 on: March 25, 2024, 04:17:09 PM »
Hi! It runs in very terrible way… very irregular at medium RPM and the engine has a bad idle and shut down after acceleration. Works fine only at high RPM.
Already cleaned intake groups and verified 150mv in total closed TPS.
Already tuned correctly, but no differences.
Thank you.
Offline flycaster
« Reply #8 on: March 25, 2024, 04:18:20 PM »
Hi! I’m not able to find it on the web site you shared.
So I may test it.
Thank you.
« Reply #9 on: March 25, 2024, 05:41:52 PM »
Thank you.
For Beetle Maps------------------------------------
http://www.griso.org/
If you send me your email via PM, I'll send you what I have. I have never used it but have looked at it, don't know what model it came from.
Has your bike always run crappy? Is it something new?
Offline flycaster
« Reply #10 on: March 25, 2024, 05:58:09 PM »
Hi, I bought the bike last month, and it always run bad, after clean and tuning too.
I sent you a PM.
Thank you very much.
Offline Vagrant
« Reply #11 on: March 25, 2024, 06:20:09 PM »
What did you set the TPS to. I seem to remember 515-540 for that one. Has the TPS been replaced recently? It's old and a common issue. There is a site I don't remember the name that sells them for under a $100. Search it here. On my 2001 the trim had to be at +30 or I had issues. Take care of the basics before worrying about a map.
2016 V7II, 2017 V7-III Blue special, 2022 V85 the fast red one! 2016 650 Versys
Offline flycaster
« Reply #12 on: March 25, 2024, 06:33:59 PM »
Hi! The TPS works correctly all over the range.
After cleaning everything and adjusted valves clearance, I set it at 150mv to the zero point, then take it to 500/525mv by the little 2.5 screw.
And so on to the other operation for the correct tuneup.
But still bad idle after accelerating (only after that) and poor performance at initial throttle aperture. Works fine only at high RPM.
Maybe someone may do a backup of the bin on his bike to share with me?
So I’m sure to start with a clean and original Moto Guzzi map for California stone.
Because, if you red up, the previous owner, confessed me to have remapped with TunerPro, but with no knowledge of what is he doing and how to rollback. Also without a backup…
PS about the CO TRIM, I found it at -4 value, but I’m not able to correct to 0. The value seems like no saving when guzzidiag tell me to shut off the emergency sto button!
Thank you.
« Last Edit: March 25, 2024, 06:40:13 PM by flycaster »
« Reply #13 on: March 26, 2024, 07:55:54 AM »
Thank you.
That would help to get the trim up. There are some oddities to getting the trim to set, like it needing to be at full temperature.
Online Tom H
« Reply #14 on: March 26, 2024, 05:35:41 PM »
As Wayne mentioned, and Guzzidiag should as well. The bike needs to be up to a certain temp to adjust and save the trim. IIRR 60C. DG should say the temp.
Is the Tuner Pro still on the bike or did you remove it? Tuner Pro should not alter the factory installed map in the ECU. Someone could have altered the stock map to make it work better with TP, but I doubt it.
When you set the TPS. You said " and so on for the tune up". When you did the TPS, you followed the instructions about removing the tie rod between the TB's? Set the TPS side and balance in the other correct?
I can send you an EV Touring bin, but I don't know what the differences are to a Stone.
Toom
« Reply #15 on: March 26, 2024, 05:48:48 PM »
Quote by OP
"Because, if you red up, the previous owner, confessed me to have remapped with TunerPro, but with no knowledge of what is he doing and how to rollback. Also without a backup…"
Offline michaell32
« Reply #16 on: March 27, 2024, 06:38:10 PM »
I have two maps saved on my computer.  One is a 61601-381-02 and the other is 61600-035-00.  I don't know which is better or what the difference is.  I can say that they both work on my 2003 california ev.
Offline flycaster
« Reply #17 on: March 31, 2024, 02:38:24 AM »
Hi! Not necessarily. I set the CO Trim to +15 by modification of the eeprom file.
And thanks to the correct map, now I obtained an optimal result!
Thank you!
Offline flycaster
« Reply #18 on: March 31, 2024, 02:41:31 AM »
Toom
Hi!
I removed the tuner pro. I would like to bring it to the original conditions.
About the TPS procedure, whit the tune up I mean the correct procedure to initial setup.
I really appreciate if you send it to me for testing.
Offline flycaster
« Reply #19 on: March 31, 2024, 02:43:24 AM »
Hi! I’ve a decent result now.
But I really appreciate if you send me your file for further testing on my bike.
Thank you very much!
Offline michaell32
« Reply #20 on: March 31, 2024, 07:13:01 AM »
I don't know how to attach the bin file through the PM.  It only lets me add links or images.
« Reply #21 on: March 31, 2024, 08:42:26 AM »
You have to send it in email attachment for it to get there.
Just wondering if he used the bin file I sent him. Glad he's getting some results now.
