Author Topic: Source for auxiliary lights for my 2013 Stelvio?  (Read 930 times)
bobrebos
« on: October 08, 2019, 05:58:55 AM »
One of my auxiliary lights broke/snapped off at its mounting location on my 2013 Stelvio.  Can anybody give me a link for a source for some that i can replace the existing ones with and use the same wiring/existing switch etc.  If I replace the stock ones with aftermarket, the inside wire chafing issue should be gone also I'm thinking.  Thank-You for any links to auxiliary lights that will work with the Stelvio setup.  Ride safe!   :bike-037:
Offline Zoom Zoom
Re: Source for auxiliary lights for my 2013 Stelvio?
« Reply #1 on: October 08, 2019, 07:01:46 AM »
Its been quite a while, but when I broke a mount I googled [hella replacement parts] and found a place that disassembled complete light kits and sold individual repair parts.
If that is of any interest to you, give it a go.
John Henry
Offline pyoungbl
« Reply #2 on: October 08, 2019, 07:58:03 AM »
I had good luck with LED lights from AdvMonster:  http://stores.advmonster.com/model-30-led-off-road-spot-light/   They draw much less power than the OEM lights, do not have the wire chafe issue, are water proof, and allowed me to keep the stock wire/switch setup.  Get the heavy duty brackets.
Peter Y.
'13 V7 Special (red/white)
Offline Green1000S
« Reply #3 on: October 08, 2019, 08:28:36 AM »
I have Denali D2’s few years. Dual intensity lights, super bright with high beams. Well worth the investment.
https://www.twistedthrottle.com/denali-d2-2-0-trioptic-led-light-kit-with-datadim-technology?gclid=EAIaIQobChMIpojD9eGM5QIVF2KGCh1XyAEKEAAYAiAAEgKQIvD_BwE
Lauri
2014 Green Stelvio NTX
2016 Stornello #101
1972 Bultaco Matador SD
2016 KTM Duke 390
1968 Riverside MW 125
Ciao!
Online Perazzimx14
« Reply #4 on: October 08, 2019, 09:39:20 AM »
I have a set of 3" LED cubes from Amazon ($30) and another set from Tractor supply that are are now $75.
While both are nice (especially for the money) the Traveler brand from Tractor Supply is brighter.
Either will easily adapt to the stock wiring. All you need is a positive and negative wire to attach to the whip hanging out of the back of the new lights.
2017 Road Glide Special
2020 Kawasaki KLX300SM
2016 Suzuki Van Van 200
Offline AH Fan
« Reply #5 on: October 08, 2019, 09:47:26 AM »
I have a brand new OEM set for you if you are interested.
PM if so.
Ciao
Online Tkelly
« Reply #6 on: October 08, 2019, 11:02:21 AM »
Be sure to rubber mount whatever you get .I  had 2 different types self destruct fron vibration.
bobrebos
« Reply #7 on: October 08, 2019, 03:35:05 PM »
I found some.  Thanks for all the responses.  Ride safe. :bike-037:
