Author Topic: 2000 V11 Sport clutch pushrod removal  (Read 424 times)
Offline Napoleanblownapart
« on: July 14, 2021, 12:16:37 PM »
Hi,
I have a 2000 V11 sport with a noisy (I assume) clutch pushrod bearing. Squeezing the clutch lever in and releasing several times (bike running in neutral) changes/eliminates the noise for a brief period.
I think this noise is the pushrod bearing. Having removed the rear wheel and unbolted the shock: I can likely get the clutch slave off, but am unclear as to weather I would be able to extract the pushrod and bearing without somehow removing the swingarm - which I hope I don't have to remove.
Has anyone had this experience?
...Carpe Cajones
1968 Greeves 36MX4 twin port, 1974 Bultaco Alpina 350, 1984 Moto Guzzi V65SP, 2001 Guzzi v11 sport, 2004 Guzzi V11 Sport, 2002 Ducati St4, 2008 Buell 1125R, 2017 KTM 1090R, 2020 Benelli TNT 135, ...
Re: 2000 V11 Sport clutch pushrod removal
« Reply #1 on: July 14, 2021, 12:42:31 PM »
Once you have the slave cyl off the hole is much bigger circumference, stick in a magnet stick and pull plunger body, bearing, rod cup in front.  Should be enough room and can angle it out if need be. Not all 1 piece but 3 in there. Might want to source the oring on slave also before reassembly.
« Reply #2 on: July 14, 2021, 12:57:31 PM »
[email[/email]
Guzzisteve - Thank you for the info. I will give it shot over the weekend and see what I find in there. I am hoping the grumpy noises are coming from the pushrod bearing
...Carpe Cajones
