Author Topic: Replacing Miu g3 ECU  (Read 666 times)
Online Zenermaniac
« on: July 19, 2021, 07:04:56 PM »
To anyone who has replaced an MIUG3 ECU - While I wait for a new one to arrive I was taking the old one out. I’m at the point where you unhook the cables but they won’t come out of the slots. It’s as if they are slightly larger in diameter than the slots are wide. I don’t see how that can be possible but they won’t lift out of the slot. They aren’t tight - they do move slightly. I didn’t want to force it so what’s the magic trick?
« Last Edit: July 19, 2021, 07:05:45 PM by Zenermaniac »
Re: Replacing Miu g3 ECU
« Reply #1 on: July 19, 2021, 09:02:00 PM »
If you look on outside there is a locknut you have to loosen on both before they will slide up & out.
Online Zenermaniac
« Reply #2 on: July 19, 2021, 09:34:05 PM »
The locknuts are loose. That’s the problem. They won’t come out through the slots.
« Last Edit: July 20, 2021, 10:40:31 AM by Zenermaniac »
Online Zenermaniac
« Reply #3 on: July 20, 2021, 10:58:06 AM »
Here’s a short video showing what I describe.
https://youtu.be/yNr7gn1d2Ck [url]]https://youtu.be/yNr7gn1d2Ck http://
Online Zenermaniac
« Reply #4 on: July 20, 2021, 05:44:32 PM »
It worked earlier. Sorry. I eventually got it out. It took a lot of force - I decided they were either coming out or break off. They finally came out. Almost like the metal had been swedged after the cables were inserted. Weird.
