Author Topic: What's a fuel tank worth?  (Read 662 times)
Offline smsw
« on: September 23, 2022, 06:35:00 PM »
What's a T3 fuel tank worth?  Any one I buy will undoubtedly need paint, but ballpark, what are these worth, assuming little to no rust inside, normal wear and tear on the outside (i.e. minimal dents/dings if any).  I'd figure without a gas cap.
Re: What's a fuel tank worth?
« Reply #1 on: September 23, 2022, 06:46:00 PM »
This auction might give you an idea. https://www.ebay.com/itm/204094392551
Offline JBU
    • www.joelurruty.com
« Reply #2 on: September 24, 2022, 10:21:06 AM »
I've got one if your interested. It had pin holes which I welded up and then sealed with with red kote.  I then painted it but never ended up using it.  Never had any gas in it since the restoration.
giphy i miss you
JBU
Offline ozarquebus
  • Grand Canyon Pack Rat
  • Riding since 1979
« Reply #3 on: September 24, 2022, 04:14:23 PM »
since we're talking about Tonti tanks here...
in comparison to the 850 T3 tank,
 is it right to assume a G5 or Convert tank is nearly identical in shape and volume, is interchangeable with only minor variations except cap types?
 Convert Hangar Queen
Offline GuzziNZ
« Reply #4 on: September 24, 2022, 04:22:49 PM »
$1000 if full of petrol!
czakky82
« Reply #5 on: September 24, 2022, 07:24:58 PM »
I think g5/convert tank has a crude fuel level sensor of some sort.
Offline smsw
« Reply #6 on: September 25, 2022, 08:33:53 PM »
Absolutely not.  They are different tanks.  If you look at Greg Bender's green Convert https://www.thisoldtractor.com/projects_i-convert.html, the Moto Guzzi emblem is above the break in the tank.  The T3 has a flat band on which the emblem sits.  The shape of the two tanks is slightly different but I have no idea if they are otherwise interchangeable.
« Reply #7 on: September 25, 2022, 08:45:03 PM »
Greg has done something "custom" or perhaps it was different on later Converts. On my '76 Convert they sit on the flat band, same on the Convert tank I just bought.
The shape is the same. The only difference between the T3 and Convert tanks is the fuel level sender port.
« Last Edit: September 25, 2022, 09:06:32 PM by Antietam Classic Cycle »
Offline guzzista
« Reply #8 on: September 25, 2022, 09:00:27 PM »
Here is a 850T/T3  welded flat where the badges depression areas were and  now wearing  V7 Sport  red and white decals with clear finish over
Offline larrys
« Reply #9 on: September 26, 2022, 08:53:28 AM »
I have a clean maroon Cal II tank that I would sell reasonable. Has a small fork tube dent.
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
« Reply #10 on: September 26, 2022, 09:33:19 AM »
To answer the OPs question.. I'd say bottom dollar would be in the $300 area for a decent one. <shrug>
Albert Einstein
