Author Topic: Mistral h-pipe with T3FB?  (Read 300 times)
Offline yackee
« on: April 24, 2024, 01:30:06 PM »
Hi all,
After a long absence I am finally getting my T3 (floorboard model) back together. I am in the process of installing a new Mistral exhaust system. I have the h-pipe too. (https://www.mgcycle.com/index.php?main_page=product_info&cPath=26_95&products_id=5864)
Just to make sure I'm not going crazy, it seems that the h-pipe doesn't work with the floorboard model, the "cut-out" on the police-style side-stand bracket forces the left-hand header close in to the frame, and leaves the right-hand header away from the frame. I assume there is no solution (apart from cutting off the side-stand bracket, which I don't want to do)?
Thoughts appreciated!
Jason
Online John A
Re: Mistral h-pipe with T3FB?
« Reply #1 on: April 24, 2024, 01:52:47 PM »
I have cut the h pipe and installed a slip joint because if it’s in a bind it will crack. I used some band clamps like the muffler clamps. I think I used clamps for an Ambassador because they have to do down small enough for a good fit on the slip joint.
Offline yackee
« Reply #2 on: April 24, 2024, 03:02:04 PM »
I guess my question is whether the T3 floor board lower rails, with the large bracket for the police-style side stand, need a different exhaust header than a non-FB bike? the problem seems to be that the Mistral header interferes with the bracket (or vice versa), so that the exhaust header can't rotate "out" from the bike to where it needs to be in order for the headers to be even/centered and for the left-side muffler to line up with the hanging bracket.
« Reply #3 on: April 24, 2024, 06:43:44 PM »
Sounds like the Mistral crossover is wider than the original. Do you have the old crossover? If so, compare the widths. If not, I should have one around that I can measure.
Offline n3303j
  • Ron Cichowski
« Reply #4 on: April 24, 2024, 09:54:58 PM »
I guess my question is whether the T3 floor board lower rails, with the large bracket for the police-style side stand, need a different exhaust header than a non-FB bike? [SNIP]
Accidentally purchased an 850T "H" pipe for my 850T3 FB. The pipe for the T is too wide at the entrance and forces the LH header into the sidestand mount as you mentioned. So I guess the answer is that a floorboard bike needs a narrower "H" pipe than one with rails.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline yackee
« Reply #5 on: April 27, 2024, 06:34:18 PM »
Interesting, thanks! The MG Cycle description of the head pipes describes them as having the correct curvature for bikes with the police-style side-stand, which they seem to have. However, the Mistral  h-pipe definitely pushes out the right-hand-side muffler a bit, so that the mufflers aren't exactly centered. My impression is that the h-pipe could be narrowed by 0.5-1.0 inches, roughly. That said, I did get both mufflers to attach to the frame at the stock hanger location. But they are slightly off-center when looked at from the front of the bike. And the mufflers have a slight "rise" going to the rear of the bike.
One other problem I had, in addition to or actually in combination with the side-stand bracket issue, was that I had also replaced the stock engine-to-frame bolts with MG Cycle's stainless steel bolts, which are threaded rods with nuts at both ends. The attraction was that I would be able to remove either side's frame rail in the future without knocking out the entire bolt. The problem was that the rod is pretty long, and if installed evenly it would further restrict the placement of the pipes, both at the front and the rear of the engine.
Offline n3303j
  • Ron Cichowski
« Reply #6 on: April 27, 2024, 06:47:39 PM »
That's what they make hacksaws for.
Some low profile nuts and a hacksaw and you have clearance.
And probably a reduction in clamping force.
I think the standard bolts are set to 50 ft/lb?
Don't know if low profile stainless nuts would support that torque?
Not sure 50 ft/lb is required to retain the engine & transmission?
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Groover
    • Scooteropolis
« Reply #7 on: April 29, 2024, 09:28:24 AM »
Interesting catch. Best to report this back to MGCycle so they can add that to their description.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Harper's Moto Guzzi : Go Ride, Break Parts, Call me!
Harper's Moto Guzzi. Where we still answer the phone, use the highest quality parts, and also do Transmission, rear drive, and carb rebuilds fast. Call us at 816.697.3411 and get your problems resolved.
http://www.harpermoto.com
