Author Topic: changing eldo fork oil  (Read 220 times)
Offline ray bear
« on: April 25, 2024, 04:07:08 AM »
have often wondered how to make changing fork oil on my 73 Eldorado with police dash easier  I  always drain the oil and refill with a measured amount through the drain plug with a syringe and have thought about installing a brake bleeder nipple to the drain hole to make it less messy but has anyone drilled the 6mm holes in the top nut all the way through and just removed the 6mm allen bolt that secures the dash to refill  with a syringe . Thanks Ray
73 V7 sport
73 Eldo police special
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
47 HRD vincent Rapide
XT 500 Yamaha
Re: changing eldo fork oil
« Reply #1 on: April 25, 2024, 08:31:28 AM »
I just raise the dash, remove the 36 mm hex plug and fill. Filling with a syringe from either end sounds like way more trouble. BTW, I use 8 oz./240 cc vs. the factory recommended 5.4 oz./160 cc.
Online normzone
« Reply #2 on: April 25, 2024, 03:00:02 PM »
It's been many years since I owned an Eldo, but I recall my mentor saying some people used automotive ATF in their forks to save money (Guzzi content, also young with no money). I tried it once, and wound up with a rigid front end, and had to go buy actual fork oil, which I recall as being very light weight.
(Oil thread) Question - What is the fluid of choice these days?
Offline jcctx
« Reply #3 on: April 25, 2024, 03:15:49 PM »
Probably more bikes with atf in the forks than any of us could count???
« Reply #4 on: April 25, 2024, 04:43:50 PM »
Drum brake forks are so crude, just about any oil works well. I've used 30w PJ1 fork oil to 80w90 gear oil and just about everything in between.
« Reply #5 on: April 25, 2024, 04:50:26 PM »
My Eldo is a hack tug.  ATF is okay for that use.
From the Deep Deep South out in left field.  There are no stupid questions.  There are however stupid people asking questions.  🤣, this includes me.  😉
« Reply #6 on: April 25, 2024, 05:17:40 PM »
I have no issues w/laying dash back on a board across the bars then use 1/2" breaker w/socket. Simple, but it's no show queen. Patina rules    I use 15W BelRay but have 20W waiting.
Harper's Moto Guzzi : Go Ride, Break Parts, Call me!
Harper's Moto Guzzi. Where we still answer the phone, use the highest quality parts, and also do Transmission, rear drive, and carb rebuilds fast. Call us at 816.697.3411 and get your problems resolved.
http://www.harpermoto.com
