Author Topic: 1975 850t  (Read 4581 times)
Offline 850brian
Re: 1975 850t
« Reply #60 on: February 02, 2024, 07:29:03 AM »
Having trouble finding what fuses I will need. Ordered a new fuse box yesterday because mine was all corroded
Re: 1975 850t
« Reply #61 on: February 02, 2024, 08:54:43 AM »
I got one of the black box ones.
The "black box ones" have about a 50% good/bad rate in my experience. This is the one I use, haven't received a bad one yet. https://www.amazon.com/gp/product/B07MJGC28B
If you are looking for the original style fuses, they are "GBC" type. Used on numerous European autos (Mercedes used them into the '90s). https://www.amazon.com/50Pcs-European-Automotive-Assortment-Bakelite/dp/B07F2739HM
Online John A
Re: 1975 850t
« Reply #62 on: February 02, 2024, 12:49:22 PM »
Those fuses usually can be found at auto parts places being called VW fuses. They have a habit of buildup on the ends so I periodically rotate them without taking them out of their clips.
Offline Turin
    • crap and stuff
« Last Edit: February 02, 2024, 01:15:54 PM by Turin »
1985 Sidlow Guzzi
1996 Triumph Daytona 1200
1996 Triumph Daytona 900
Re: 1975 850t
« Reply #63 on: February 02, 2024, 01:14:06 PM »
Offline 850brian
Re: 1975 850t
« Reply #64 on: February 02, 2024, 05:10:53 PM »
Thank you for the replies I will report back!
Offline 850brian
Re: 1975 850t
« Reply #65 on: February 02, 2024, 05:15:03 PM »
The green ones?
Re: 1975 850t
« Reply #66 on: February 02, 2024, 06:44:30 PM »
Another source for the fuses (and much more):
https://www.thisoldtractor.com/for_sale_wiring_harness_tonti_850_t.html
An 850-T should have six 16 amp fuses, which are usually red.
Online Moparnut72
Re: 1975 850t
« Reply #67 on: February 03, 2024, 07:26:35 AM »
O'Reillys has those in stock, at least in my local store. I was surprised to see them when I was getting some "regular" fuses for my RV. I hadn't seen one of those since I had my R75/6.  :grin:
kk
Mopar or Nocar
2023 V100 Marina
2019 V7lll Special
MGNOC #24053
Offline 850brian
Re: 1975 850t
« Reply #68 on: February 03, 2024, 10:59:56 AM »
Awesome! Thank you.
Offline 850brian
Re: 1975 850t
« Reply #69 on: February 13, 2024, 03:36:36 PM »
Still no luck w new flasher, fuse box and fuses
Re: 1975 850t
« Reply #70 on: February 13, 2024, 03:58:36 PM »
Time to go through every connection on the bike, making sure they're clean and tight, all of the ground points as well.
Offline 850brian
Re: 1975 850t
« Reply #71 on: March 24, 2024, 04:55:43 PM »
So I installed a new main harness which fixed the tail light problem but now my head light is not working. Does anyone know where this wire should be?
Re: 1975 850t
« Reply #72 on: March 24, 2024, 09:27:40 PM »
Just guessing, but blue is used for the charge warning light circuit. If that's what it is, then it connects at the diode board/rectifier.
Offline 850brian
Re: 1975 850t
« Reply #73 on: March 27, 2024, 11:05:39 AM »
Update. I got the new harness installed and it fixed my problem! Only my headlight worked before I installed it. Now I have tail light dash lights and turn signals, however...... now I don't have a headlight? Any suggestions on what to look for?
Online Tom
Re: 1975 850t
« Reply #74 on: March 27, 2024, 12:34:09 PM »
Take a multi-meter and check for power to the headlight.  Work your way back from there.  Could be corrosion in the ignition switch if you still have the hem one.  Check power in/out of the switch.  The oem ignition switch can have corrosion and/or bakelite build up on the contacts.  Be very careful when prying up on the metal tangs that squeeze/hold the switch together.
From the Deep Deep South out in left field.  There are no stupid questions.  There are however stupid people asking questions.  🤣, this includes me.  😉
