Author Topic: new billet fork brace for my project.  (Read 878 times)
Offline Turin
    • crap and stuff
« on: January 14, 2022, 06:41:19 PM »
Fork brace for my LeMans 1000 forks
« Last Edit: January 15, 2022, 12:23:45 AM by Turin »
1985 Sidlow Guzzi
1996 Triumph Daytona 1200
1996 Triumph Daytona 900
Re: new bit for my project.
« Reply #1 on: January 14, 2022, 06:57:17 PM »
Nice! Where did you get that?
Offline Turin
    • crap and stuff
« Reply #2 on: January 14, 2022, 07:04:00 PM »
Had it made  :azn:
1985 Sidlow Guzzi
Offline lucky phil
« Reply #3 on: January 14, 2022, 08:16:57 PM »
Looks nice. Did you slot the mount bolt holes?
Ciao
Offline cliffrod
« Reply #4 on: January 14, 2022, 08:36:59 PM »
Very cool....
Offline Turin
    • crap and stuff
« Reply #5 on: January 15, 2022, 12:23:02 AM »
I don't think he did. This guy did the flywheel fork brace and triple clamps on my Lemans SE.
1985 Sidlow Guzzi
Offline lucky phil
« Reply #6 on: January 15, 2022, 03:42:35 AM »
I suggest you support the front of the bike and remove the fork caps and check the forks through their full travel for any sign of binding. I've fitted quite a few of these old style braces years ago and they were always adjustable to prevent fork binding or high friction through the travel.
Ciao
« Reply #7 on: January 15, 2022, 06:42:56 AM »
Ciao
This..a few thousandths makes a difference.
Albert Einstein
Offline Turin
    • crap and stuff
Re: new billet fork brace for my project.
« Reply #8 on: January 15, 2022, 01:39:36 PM »
That's the main reason I didn't suggest we make a bunch and start selling them. Last thing I want is to be known as the guy who is responsible for someones suspension woes. The brace for my SE was made years ago by the same guy. the bike is being put together by Tom Hull. He knows suspension well.
ocee elementary
1985 Sidlow Guzzi
Offline drdwb
    • backfeelsgreat.com
« Reply #9 on: January 16, 2022, 11:12:42 AM »
That brace might be a great add on for bikes running side cars with normal forks. Would your guy be interested in building them for California models?
Offline lucky phil
« Reply #10 on: January 16, 2022, 04:47:57 PM »
Yep. There is a guy on the Royal Enfield forum making up very very nicely CNC's fork braces, they look really nice, except. He's designed and made them using 4 countersunk cap screws to attach it. I think he may be selling them on ebay as well, not sure. Didn't understand what the issue was when pointed out. The difference between being a good machinist and a good engineer I guess. I even found the std fork brace on my RE 650 needed shimming under one of the mount points so it wasnt slightly twisted when tightened down. Not much, about .005" or so.
Ciao
Offline Moparnut72
« Reply #11 on: January 16, 2022, 06:32:22 PM »
I'll bite what is wrong with countersunk cap screws? Enlighten me please.
kk
Mopar or Nocar
2023 V100 Marina
2019 V7lll Special
MGNOC #24053
Offline lucky phil
« Reply #12 on: January 16, 2022, 06:42:54 PM »
kk
Zero tolerance for misalignment. If there is any slight variation in dimensions of the fork legs due to manufacturing tolerances the brace cant adapt to that if the mount points are fixed at one dimension via countersunk holes. They always need some extra hole clearance or some form of adjustability or slotted holes.
Ciao
« Last Edit: January 16, 2022, 06:44:27 PM by lucky phil »
Offline Moparnut72
« Reply #13 on: January 16, 2022, 06:54:19 PM »
Ah yes. Makes perfect sense.  Thanks.
kk
Mopar or Nocar
2023 V100 Marina
2019 V7lll Special
MGNOC #24053
Offline Stevex
« Reply #14 on: January 17, 2022, 10:46:27 AM »
Got this one fitted to my LM2. All parts cast, clamps are machined and a very good fit to the stanchions; the top brace's 4 mounting bolts have 'wiggle' room, but solid once done up. I found this mod a required upgrade for the 35mm forks; it stopped the caliper pistons being pushed back on bumpy roads.
Offline acguzzi
« Reply #15 on: January 17, 2022, 10:51:11 AM »
love the guzzi logo, very nice
