Author Topic: Resistance is futile-LED signals  (Read 499 times)
Offline guzziownr
« on: March 21, 2024, 02:19:34 PM »
1970 Ambassador did not come with signals so homebrewed up a set of LEDs from the mysterious East.
They light up when switched but do not flash -- Yes I am using an LED flasher module!
Tested with an incandescent 12V bulb it works fine. Can I just add load to the circuit at the flasher with an Incandescent bulb or resistor?
I would prefer not to have to wire one for each signal.
Wiring is very simple: 12V---> flasher--->switch--->bulb--->ground
Offline bigbikerrick
Re: Resistance is futile-LED signals
« Reply #1 on: March 21, 2024, 02:46:51 PM »
If you use a flasher made for LEDs it should sense the voltage and flash. I would try a different flasher, maybe  a better quality one? I once bought one off amazon that was supposed to work with LEDs and it did not work, a different one did.
Rick.
Online StuCorpe
« Reply #2 on: March 21, 2024, 03:00:29 PM »
I had the same experience as bigbikerrick, from Amazon.  Went down to local auto supply store and got one that worked just fine.
« Reply #3 on: March 21, 2024, 04:17:51 PM »
1970 Ambo?  Do tell…
Cam
Offline guzziownr
« Reply #4 on: March 21, 2024, 04:25:13 PM »
1970 Ambo?  Do tell…Cam
Nothing exciting, just helping a friend.
« Reply #5 on: March 21, 2024, 04:31:28 PM »
I agree, try another flasher relay. I bought one for my '62 F100 to add LED. Didn't work. Bought another style/brand and it worked.
« Reply #6 on: March 21, 2024, 04:49:18 PM »
I use this one. https://www.amazon.com/gp/product/B07MJGC28B . Make sure you're connecting it correctly, they're polarity sensitive.
Offline guzziownr
« Reply #7 on: March 21, 2024, 06:49:53 PM »
Thank you Charlie, I will give it a try.
Offline larrys
« Reply #8 on: March 25, 2024, 11:24:50 AM »
I had the same issue with my Cal when I went to LED emitters in the turn signals. A no-load flasher from Greg Bender did the job.
Larry
« Last Edit: March 25, 2024, 11:25:48 AM by larrys »
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
