Author Topic: G5 Brake Valve  (Read 825 times)
Offline Scout63
G5 Brake Valve
« on: June 14, 2021, 07:07:12 AM »
Is the rear-mounted brake splitter union a proportioning valve or just a three-way splitter for dividing fluid between the front and rear calipers?  I’ve installed this Brembo splitter in my build connecting the rear master cylinder, rear caliper and front left caliper and now am concerned that it will change the braking system:
https://www.mgcycle.com/index.php?main_page=product_info&products_id=3154
Thanks - Ben
Ben Zehnder - Orleans, MA USA
Re: G5 Brake Valve
« Reply #1 on: June 14, 2021, 08:19:52 AM »
If the original had a round rubber cap approx. 30 mm in diameter on one end, it was a proportioning valve. Otherwise it was just a splitter/manifold. The parts diagram shows a splitter/manifold.
« Last Edit: June 14, 2021, 09:18:17 AM by Antietam Classic Cycle »
Re: G5 Brake Valve
« Reply #2 on: June 14, 2021, 08:51:23 AM »
The integral slitter has no valve. Its a series of different size holes. The faster & harder you hit the foot brake it puts more pressure on back or front. It works on imput pressure to make the difference.
« Last Edit: June 14, 2021, 08:52:02 AM by guzzisteve »
Online Groover
    • Scooteropolis
Re: G5 Brake Valve
« Reply #3 on: June 14, 2021, 11:11:00 AM »
I believe the "proportioning" was done by using different brake pad grade as OEM on the front left, though we all change them to be all 3 (6) the same, but in reality to be correct braking per design, the pads on the front left should be harder grade, that's why I think you see a lot of left front disks maybe look more grooved than the right ones.
That's my conclusion at least  :azn:
« Last Edit: June 14, 2021, 11:11:49 AM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Re: G5 Brake Valve
Online moto
  • Potrebbe andare peggio, potrebbe piovere!
Re: G5 Brake Valve
« Reply #4 on: June 15, 2021, 09:58:07 AM »
Hi Groover,
With all respect, I believe you may be wrong about this, at least for the original T3 system. The part number for all three sets of pads is the same, namely 14 65 46 01, in the parts manual.
My understanding has always been that the front-to-back braking balance is 50/50 from the foot pedal in the original system, with additional force to be applied at the front for hard stops by pulling on the hand lever.
Moto
« Last Edit: June 15, 2021, 09:59:04 AM by moto »
850 T-3
Griso 1100 corretto
Online moto
Re: G5 Brake Valve
« Reply #5 on: June 15, 2021, 11:16:01 AM »
Right. The G5 diagram shows the same, simple manifold with four threaded ports as my T3's, not quite functionally equivalent to the part you installed. Here it is, part number 17 66 80 50:
The difference is that your part lacks the fourth port for the brake light switch. (Edited to correct my initial oversight of the missing port )
« Last Edit: June 15, 2021, 11:22:29 AM by moto »
850 T-3
Griso 1100 corretto
Online Groover
    • Scooteropolis
Re: G5 Brake Valve
« Reply #6 on: June 15, 2021, 01:13:16 PM »
Hi Moto, no offense taken. I am married, and "you're wrong" is an endearing word combination to my ears now  :azn:
In regards to the pads, not familiar with the T3 manual, but the G5 part manual shows the Front Left as Ferit I/D 330, and  Ferit I/D 332 for the Front Right and Rear.
Though, at this moment I don't recall if I ever did figure out if 330 is harder than 332, but that would make sense to me. The Moto Guzzi part numbers are 14654650 for the 330, and 14654601 for the 332 (same as T3 for these two)
« Last Edit: June 15, 2021, 01:16:45 PM by Groover »
1980 Vespa SI Moped
Online bmc5733946
Re: G5 Brake Valve
« Reply #7 on: June 15, 2021, 01:49:15 PM »
According to Guzziology (thanks Dave Richardson) the USA G5 had a 4 way manifold 1766 8050, no proportioning. Dave gives a complete list of valves/manifolds and their ratios. Guzziology is a most wonderful resource!
Brian
1989 MILLE GT
2004 BREVA 750
1975  Convert
Offline 1down5up
Re: G5 Brake Valve
« Reply #8 on: June 15, 2021, 03:08:13 PM »
Just to add to the conversation  - the SP1000 (possibly G5 though not sure) had a Brembo F09 rear caliper which had a 48mm Piston rather than the normal F08's (38mm) - so even though they had a standard 4 way cplitter with no proportioning valve the rear brake had a larger piston which changed the actual pressure application balance
Online moto
Re: G5 Brake Valve
« Reply #9 on: June 15, 2021, 03:22:10 PM »
The G5 parts diagram shows the same part number for the front right and the rear caliper, indicating they are both F08's.
850 T-3
Griso 1100 corretto
Online moto
Re: G5 Brake Valve
« Reply #10 on: June 15, 2021, 03:35:34 PM »
Ah, big thanks to your wife for desensitizing you! 😁
So the T3 and G5 differ in that a different compound has been specified for the front linked brake, changing the front-rear balance when using only the rear pedal. The only reason I can see for putting less force on the front tire is when braking on dirt. That would require a harder compound. Is that your reasoning? Or something else?
I have to admit I am very fond of the great simplicity of the original system, where the selection of components and the use of the same compounds all around means that each disc contributes the same force for the same input pressure.
Moto
850 T-3
Griso 1100 corretto
Online Groover
    • Scooteropolis
Re: G5 Brake Valve
« Reply #11 on: June 15, 2021, 04:13:01 PM »
Yes, that would be my reasoning. Basically if hitting that rear brake hard with your foot, using the harder compound in my mind would have less friction than a softer compound, so everything else being equally, you get more braking/friction in the rear less in the front with the linked brakes (safer for various surfaces, such as gravel) in lieu of a proportioning valve, but you can then supplement more braking in the front as needed using the right lever (front right brake pads) like non-linked brake type bikes.
I also like the linked brakes, makes a lot of sense to me, and I also like they didn't link all three in case there is a failure in one system, then you have the other.
« Last Edit: June 15, 2021, 04:13:09 PM by Groover »
1980 Vespa SI Moped
Online Frenchfrog
Re: G5 Brake Valve
« Reply #12 on: June 15, 2021, 04:29:28 PM »
Not certain but that was only in certain markets...UK and France had 08's , Germany got the 09.Or the 09 bins were empty at some points  :laugh:
« Last Edit: June 15, 2021, 04:30:15 PM by Frenchfrog »
Online bmc5733946
Re: G5 Brake Valve
« Reply #13 on: June 15, 2021, 05:04:43 PM »
Guzziology lists the SP1000 with the F09 as well as a 4 way proportioning valve 1866 8560. While listing the SPII with 4 way manifold 1766 8050 and the SPIII with 4 way proportioning valve 1966 8565. Just trying to provide information. There are many variations, keeping them straight seems prudent.
Brian
1989 MILLE GT
2004 BREVA 750
1975  Convert
Offline Scout63
Re: G5 Brake Valve
« Reply #14 on: June 15, 2021, 08:56:53 PM »
I ran a short brake line from the rear mc to the three way port and banjo’d the front left brake brake line off a Goodridge single banjo pressure switch in the second port.  The third port runs to the rear brake.
https://www.mgcycle.com/index.php?main_page=product_info&products_id=1583
Great feedback.  I feel better.
