- I have read multiple threads (not only on these forums) regarding the issue and as the knocking sound is going from the left cylinder and obviously only when idling, me and Guzzi service is assuming that the knocking is caused by larger valve's clearance as the tappets are worn. Is there a chance that the issue could be caused by a different issue and thus Guzzi will not supply the parts within the claiming campaign?- Why the left cylinder/head is starting to produce the knocking sound first, rather than the right cylinder/head?- New, upgraded, rolling tappets - does those solve the issue permanently usually?
Thanks.Well, as I checked the Stelvio last time, I think the sound was coming from the top of the cylinder, rather than bottom end of the engine. I also understand that if the wear level of the tappets is high, metal particles separated from the tappets could be spread across multiple bearings and sliding surfaces, causing additional damage. Inspection will be done by Guzzi authorized service (they are making only Guzzis and for 25 years now, so I am assuming they know what to do/check/inspect. The Stelvio has 20.000 miles on the clock) on Monday next week to check the sound source and tappets/camshaft wear level, I will also remind them to check the sump for the metal particles. Is there some magnet in the sump of Stelvio, to catch any kind of metal particle? (I know that cars have the magnet in the sump).
I would say it is not as intensive as an hammer beating into an iron. More likely the clicks, but audible even the engine is running. Hard to describe. I do not remeber if the problem was there when pulling the clutch lever.I paid reservation fee for the Stelvio and agreed with the seller that full price will not be paid until fixed in authorized service.
Hi there!I am new on these forums and already provided my introduction in the appropriate thread.I am about to buy used Stelvio '09 ABS which has 'knocking' issue from the left cylinder/head, other way the Stelvio is in the perfect condition, with all the original markings on the screws, original harnesses etc. Authorized Guzzi service told me that the servicing database does not contain a record about flat tappets upgrade to rolling tappets, thus if the knocking issue is caused by this failure, Guzzi will supply upgraded parts (rolling tappets) free of charge. I like the bike very much, thus I decided to buy it altough it has the knocking issue, hoping that Guzzi authorized service will fix it. I would like to put few questions into the place:- I have read multiple threads (not only on these forums) regarding the issue and as the knocking sound is going from the left cylinder and obviously only when idling, me and Guzzi service is assuming that the knocking is caused by larger valve's clearance as the tappets are worn. Is there a chance that the issue could be caused by a different issue and thus Guzzi will not supply the parts within the claiming campaign?- Why the left cylinder/head is starting to produce the knocking sound first, rather than the right cylinder/head?- New, upgraded, rolling tappets - does those solve the issue permanently usually?I will have more info on Monday next week when the Stelvio is going to the service to check the knocking issue diagnosis.Thanks Guzzi Petrolheads!Lucas
They've also told me that part of the upgrade will be oil change, sump and oil cooler cleanup and bottom end inspection.Did they miss something?
I would say B kit. Bike is build: 30.03.2009 GU9032751EU902 STELVIO ABS EU NERA
Sounds right.You probably need a 'C' kit. That requires a good bit more labor time, so may not be cheap.If the oil filter did it's job, you should have a great running motor when it is done.
So when reading this:and this:Which kit do I need actually? I am a bit confused? I understood from the service that they will recognize that according to markings on the engine itself but since that time I was not talking with them.
